Columbian looks really nice.
On the Parker, you're going to paint on top of BLO treatment? Figured that would cause adhesion issues.
Scott
Really nice work, Great Job!
BLO can be used as a paint additive so it actually acts like primer. It also seems to soak into cast iron sealing it.
Little teaser of the Parker 2x which I painted this morning. Still need to bake it. I paint the underside of my vise bases, and fixed base are a pain to bake without messing up a painted surface. I let this one air dry so I can actually hold it without accidentally getting a fingerprint on it. I'll bake it tomorrow.
$600?!?!?! You're kidding right? The first one I bought was at an old farm estate sale in Connecticut. We made a deal on $5 as long as I removed it from the bench. My brother in law currently has that one. I think this freebie may be a keeper
Thanks. It's going to be a project for my 8 yr old to go on his workbench. He has collected a neat little cast anvil, a older Craftsman ball-peen and a few other tools. He already looks for tools at the flea market or garage sales.
I'm looking at getting a prentiss vise and it appears to have a spring loaded pin that falls into index holes in the base to lock the swivel.
Anybody have any experience with that style of lock?
Do they lock up tight?
Do they lock up as tight as a clamp bolt?
Are they snug enough to not be a bother when hand sawing, filing, chiseling or planing?
Thank you
Royce
Thank you
Royce
SEBER: i hope your vise jaw's screws are not broken or stripped. i also hope you vise nut and back piece don't have any broken cast. crossing our fingers that you didn't buy a parts vise. did you notice any missing issues or cracks before you bought your Wilton? how wide are the jaws?
Here's the Morgan 60 that I picked up recently - 6" jaws, 143 lbs. She's a big'un. Has seen a lot of use, but still in very good condition. Will strip off the recent repaint and go back with factory medium/light blue. Morgan still sells parts, too -- will pick up a set of jaws along with a pin to keep the vise nut in place.
Paint came off easily enough. Just sprayed some brake cleaner on it and wiped it off or scrubbed a bit with a small brush.
Had a bit of welding spatter on it, but 5 minutes with a chisel and small ball peen took care of that. Will spend some time cleaning it up a bit more with a file and some sandpaper on my angle grinder. Will follow this with some sandblasting to give the surface some bite for the paint to adhere to.
The nut fits pretty loose in the static jaw. Will take some measurements and see if Morgan can tell me whether the nut is too small/too worn, or if the female portion of the static jaw is hogged out. Either way, I'd like to tighten it back up a bit. Had some slop in it.
The pin holding the vise nut in place was missing; some knucklehead jammed a bolt in there and tightened it up pretty good. Managed to get it out, but had to drill two holes in it and then beat it out. I'll drill it out a bit oversize and get a new pin for it.
Took a bit of work to get the jaws out. Some of the screws holding the jaws in were worn/ground flat on top, so there was no slot for the screwdriver. Got 'em out with a chisel and/or impact screwdriver (after chiseling a slot for the impact screwdriver).
New jaws are about $90 from Morgan. The ones on mine are useable, but not great. I'll get some new ones ordered.
Neighbor got me this one from his friends garage sale.
I'm loving the Craftsman vise, Mike. Looking forward to seeing it cleaned up! What did you pay for it?
Brian
Helped the neighbor replace his pitman and idler arms on a 97 sierra
GMAN: Prentiss just stamped on parts #'s so they would know which parts belonged to which vise. not a date stamp. i'm guessing yours is from the early 20's and the catalog pages were posted on here once or somebody has some that might give you a better date. looks good BTW
Chilang: your skills at vise spiffing were good when you started and keep improving. WELL DONE
ALL: this SWEDISH VISE just came up on CL in Portland,Or in case any of you might want one. it seems to have a lot of options and since i have more than a few vises or vices i'm going to pass on this one for the time being. it's a MALCUS brand. anybody own one or has one been posted before?
