Can you guys recommend me a 1-2 ton portable hydraulic jack that can be used for changing flat tires on a regular car when on the road?
I need a brand name that can be easily purchased in the EU; those Chinese hydraulic jacks found in auto parts stores and supermarkets are pure junk!
GühringWhat is the go-to for a fancy European tap and die set?
could be the same thoughSometimes there happen wonders............the Coo has changed positively !
the ones mentioned or Mega www.mega.esCan you guys recommend me a 1-2 ton portable hydraulic jack that can be used for changing flat tires on a regular car when on the road?
The "Bravo" brand was owned by a company called "Gebr. Schreiber". The brand name was deleted in 2001.Hi Monte,
Do you have any info or website about the Bravo brand? I could not find about it. One of the drivers was tested under extreme conditions. They are very rigid alloy steel is!![]()
Ideal tools are the classic garden tools with wooden handle and metal "head". The choice (usually) for pros but also many DIY users. The Wolf (+ Gardena) tools are a good choice (imho) for the DIY user because you only need very little space for storage and the individual heads are (mostly) only around 10 bucks each. I do some garden work for neigbours so i throw the heads in a bucket and take a handle with me so i´m equipped without hauling dozens of tools (with handle) around. For professional use: I don´t know if the connection head/handle will last "forever". Wolf vs. Gardena: I liked the Wolf push button disconnect better than the screw type. Coo: Wolf mostly Germany, Gardena: Czech Rep. (Metal parts), Germany (Plastic parts + shears etc.), Ideal: spades Germany, rest mostly unlabeled.Hi Monte,
How do you find the garden tools compared to Idealspaten?
If i assume that Stahlwille pliers are supplied by VBW and VBW electronic pliers look like thisDo you know who makes the electronik cutters for Stahlwille and how they compare lets say with Schmitz, Swanstrom?
They look like rebranded Schmitz to me (they make both box & lap joint models).Do you know who makes the electronik cutters for Stahlwille and how they compare lets say with Schmitz, Swanstrom?
View media item 61425
Thank you!
Seems VBW is also rebranding Schmitz.If i assume that Stahlwille pliers are supplied by VBW and VBW electronic pliers look like this
while Schmitz pliers look like this........maybe they just have the same handle supplier... Or Stahlwille has a different electronic pliers supplier because their handles are different.... ? I don´t know...
Swanstrom is not really available here... Schmitz, Erem, Lindström, Wiha, Bernstein etc. are the common brands over here.
Nanofrog,They look like rebranded Schmitz to me (they make both box & lap joint models).
Schmitz's cutters are excellent, as are their pliers (teeth haven't flattened out, unlike others).
Swanstrom are excellent cutters as well, but by the time you import them into the UK, they'd be overpriced. Same with Tronex, which have the same type of construction & grips (long handles w/ foam).
You'd be best off to buy Schmitz IMHO, as they're less expensive than the other brands, and the quality & performance are excellent.
FWIW, I own cutters from Schmitz (CK Tools label), Erem, Swanstrom, Lindstrom, Tronex (rebranded as Excelta), and Belzer. Tronex are my absolute favorites due to the grips (I'm 6'-4"); Swanstrom's basic construction is identical, and on par with Tronex.
The only ones I'm not terribly fond of, are my Lindstroms as they take more force to use for a given wire size (feel like the grips are going to break off given the amount of flex in them). The rest cut like a hot knife through butter. [emoji106]
So it came down to grip fit for me. The Erem's I have are their ergonomic versions, and they slip a bit too much for my liking; they're otherwise excellent (assuming you can get over the sticker shock). The older, foam grips would have been a better choice in my case.
I don't own a lot of Schmitz cutters, as I wasn't aware of the actual manufacturer of CK Tools or Bernstein when I purchased the bulk of my cutters. And the rebrands are double the price or more on average here, so the value wasn't there via that route.
My pliers OTOH, are mostly Schmitz.
As an aside, I prefer a semi-flush hone on the blades (leaves a very small spike). They cut smoother than full bevel (less hand force required), yet have the same wire cutting capacity in the vast majority of cases, and a similar lifespan as well. [emoji106] Full-flush OTOH are very delicate and damage too easily (= shorter lifespan), nor do they go as large on wire sizes for the same size of cutter otherwise (grip length & head size).
FWIW, Schmitz does a lot of rebranding (main part of their business).
Thanks Monte,Ideal tools are the classic garden tools with wooden handle and metal "head". The choice (usually) for pros but also many DIY users. The Wolf (+ Gardena) tools are a good choice (imho) for the DIY user because you only need very little space for storage and the individual heads are (mostly) only around 10 bucks each. I do some garden work for neigbours so i throw the heads in a bucket and take a handle with me so i´m equipped without hauling dozens of tools (with handle) around. For professional use: I don´t know if the connection head/handle will last "forever". Wolf vs. Gardena: I liked the Wolf push button disconnect better than the screw type. Coo: Wolf mostly Germany, Gardena: Czech Rep. (Metal parts), Germany (Plastic parts + shears etc.), Ideal: spades Germany, rest mostly unlabeled.
Knipex shears
Some screwdriver sets i have for sale:
http://up.picr.de/25902127jk.jpg
Hi-Q Tools (Wera) €16.-
http://up.picr.de/25902135br.jpg
Wisent (Wiha) €25.-
http://up.picr.de/25902181qj.jpg
Bertool (Witte) € 30.-
http://up.picr.de/25902183yd.jpg
Sorry I forgot the Larsson made in Sweden ones with box joint construction[emoji4]Nanofrog,
It seems that you know a bit about these pliers[emoji3] [emoji106]
May I ask you if the Lindstrom ones you are referring to are the ones made in Sweden, the box-joint and lately the screw-pin, or the ones made in Spain?
Thank you and have a good day!!!
Sent from my HTC Desire 620 using Tapatalk
COO = Spain, which uses the newer type of lap joint rather than a box joint.May I ask you if the Lindstrom ones you are referring to are the ones made in Sweden, the box-joint and lately the screw-pin, or the ones made in Spain?
Larsson no longer exists, so if you find any, they're either used or NOS (bought up by Ideal-Tek).Sorry I forgot the Larsson made in Sweden ones with box joint construction
).COO = Spain, which uses the newer type of lap joint rather than a box joint.
Regarding cutters, a lap joint is fine. For pliers OTOH, a box joint is preferable, as they get stressed on multiple axis.
Ideal-tek's cutters are good as well as I understand it (they make the EX line for Lindstrom), as are their tweezers (they're also the ODM for Lindstrom's tweezers). FWIW, I'm well acquainted with their tweezers.
Do note that Ideal-tek's cutters & pliers don't use box joints, so I'm not sure if it was something Larsson developed but hadn't released, or if it was their own design (if the latter is the case, I can't figure on why they'd want to buy Larsson).
I own a Dewalt D28886 which is a rebadged Metabo GE 700 . It´s a nice tool with spindle lock so you need only 1 wrench which is convenient. It has constant electronics and all other features. It´s a bit thicker than the Fein and a bit heavier i think (the spindle is made from steel pipe). It´s a nice tool. (btw. mine is for sale)
all tools should have constant electronics !
pics ?
Momento 3/8" drive SAE impact sockets from 1/4" to 9/16":
www.Momento.se
Thank you monte for info.
Belzer stubby drivers :
<img border=0 src="http://matchbox.persiangig.com/DSC03644.JPG">
<img border=0 src="http://matchbox.persiangig.com/DSC03646.JPG">
VBW side cutter :
<img border=0 src="http://matchbox.persiangig.com/DSC03643.JPG">
<img border=0 src="http://matchbox.persiangig.com/DSC03464.JPG">
<img border=0 src="http://matchbox.persiangig.com/DSC03465.JPG">
They're very much like the original Swedish made Lindstroms.Yeah, I have found some NOS Larsson box-joint design cutter MADE in SWEDEN and wondering if they are good so I can buy them. Some people rate them closely to old Lindstrom.
Thanks[emoji3] [emoji106]They're very much like the original Swedish made Lindstroms. [emoji106] So if it's what you need (right jaw shape & cutting edges), and the price is right, grab them before they're gone.
Just take care not to drop them on the tips, as you can snap a jaw off that way.
i think soSeems VBW is also rebranding Schmitz.![]()
Thanks for joiningThanks Monte,
Thanks to you that started this educational thread we have been full of knowledge and empty pockets[emoji16]
Here´s their distributor list: http://www.momento.se/distributors/Hallo Monte,
Where we can buy Momento??
nice vintage toolsBelzer stubby drivers :
i think so
Thanks for joining
can´t find UK though....
Maybe they can help you:
https://www.toolorders.co.uk/momento-impact-sockets?page=1
nice vintage tools
Uvex gloves
Some ratchets i have for sale:
http://up.picr.de/25910945tt.jpg
Hazet 916-1 (1/2") €40.- (slightly used), Hazet 8816-F (3/8") €35.- (new), Dowidat (3/8") €35.-(new), Tone (3/8") €20.- (new)
Hello again,They're very much like the original Swedish made Lindstroms. [emoji106] So if it's what you need (right jaw shape & cutting edges), and the price is right, grab them before they're gone.
You won't damage them doing this, as I do it all the time.Hello again,
Could these cutters be damaged if occasionally cut soft plastic of small thickness like shrinking tubes?
I am thinking if they good for copper/ aluminium they would be ok for plastic?
I am always try and combine the use of tools within limits of course[emoji16]
Thanks!
This is where I use my Swanstrom S512E (largest precision cutter I own).
And it's still going strong.
The brand nowadays belongs to the company www.doenges-rs.de
But they don´t produce anything anymore.
I'd bet on that being a Wera handle.
Berger 600mm loppers
