Carlyle ratcheting flare nut wrenches
gdocktor3
Connecticut
Because of the sheer size of them, I don't see them being practical in most cases. I see them being useful in the plumbing/HVAC trades or something like that where you have the room to fit that big bulky head, but thats it. I wouldn't buy them. I'll show you what I have instead - http://imperial-tools.com/content/195-f-kwik-tite®-ratchet-wrenches
Proto, Ridgid, Williams, Snap On and Armstrong and others also make them.
If you like the Carlyle type, check these out. They're cheaper and probably the exact same. http://www.ebay.com/itm/6-PC-Ratche...id=100009&rk=1&rkt=1&mehot=lo&sd=191892059824
CutterFarms
Kentucky
I don't think they would see much use because of the shear size of them, but in all fairness I've wasted alot more money on worse than that, if you buy them you will always find something to use them on.
Fedwrench
Valley of the sun
Sorry, not impressed. The area with hinged joint is simply too big for most applications I work on. I'm sure they'll work as advertised but, you'll quite a bit of space to use them. :dunno:
Let us know how they work out for you.
Hiball
Missery
Ehh... I had a set of the Imperial ones branded thru Wright, IMO they where more trouble than they where worth. Its why I prefer the line wrenches that are single sized with a open end for speed, then again I don't get paid by the job so it's not a big deal. Report back..
gdocktor3
Connecticut
Here is the video.
That video is showing the X Force version, same brand of the ones I linked above, for much cheaper. If you do buy them, go with the X force over the Carlyle brand. Also, did you notice how "out in the open" that flare nut was in the video? I can see myself using a long, flat head screwdriver and a myriad of other tools trying to get that jaw open in tight places. Most of the flare fittings I work on are tight against the frame, another line, or something..
Anyone ever been to the X Force website? They make some weird stuff... Check it out http://agscompany.com/resources/photos/xforce-tools/
T
toolaholic
PA
I ordered Carlyle in metric 8-15mm. Ordered 5/16 to 3/4 in sae X force. Plus ordered a Armstrong 18mm ratcheting fkex from cripe. I just think they are neat. Thanks for the X force tip.
