Recommend me a Jigsaw
Rich.
Newcastle, Uk
Im looking at picking up a new jigsaw as im starting to build my woodworking tool collection up a bit as its severely lacking. Im looking for a top handle. I've pretty much tied it between the Metabo STEB140 and the Bosch GST150 BCE (Sorry if these are UK part no's, its not easy to find the US numbers when search engines are constantly trying to redirect you to a uk page!)
Anyone have any input or recommendations? Festool is a bit out of my price range and i see quite a lot of bad reviews of their jigsaws to be honest.
Thanks
Rich
toolsRme
I upgraded my Jig Saw last year from an old 1970's Craftsman to a new Orbital Milwaukee model and have been quite happy so far. No issues at all and it has plenty of power. I went with a CORDED model as I am DONE with batteries! Slightly more time to run an extension cord (if outside) but I never have to worry about the battery crapping out anymore. :)
Wamsutta
Amarillo, Texas
I'd recommend one of the upscale Bosch models with the blade pincher guide deals; the lower end models don't have that.
Bunk
Alexandria, VA
I've been completely satisfied by my Bosch that I've owned for the past 20 years. Wow, just hit me how long I've had it. Never a need to update or upgrade.
Ainsley
Ontario, Canada
I have the highest end Bosch jigsaw at home and it has been awesome, I highly recommend it. I also have the cordless metabo jigsaw at work and its a nice tool too but i prefer the Bosch.
Irongrave
Florence SC
I'm not a fan of the Festool Jigsaw that I have at work. Granted its not a top handle model so its just weird to use after only using top handle ones. Personally I have a 18V battery Makita that is a great comfortable tool.
TMcCay
SW. Oklahoma
I have owned my Bosch for almost 20 years and have never had a issue with it. Would replace it with another in without hesitation.
MoonRise
Jigsaw?
Whatever the current 'top line' Bosch model is. The model with the blade eject feature (trust me, even if you don't think you want or need it, you really do :D ), and the blade support and so on.
R
Rich.
Newcastle, Uk
rlitman
Long Island
+1. That's a feature I've only seen on the top line from Bosch and from Festool.
Jigsaw?
The blade eject is a GREAT feature because you don't need to touch a hot blade to remove it (most other tool-less blade clamps still require you to pull the blade out. It sounds silly, but Bosch really got this one right.
As for which model, I have a strong preference towards barrel grip over top handle, but since the OP does not (to each his own), for a US user, I'd recommend finding a used 1590 (the 1591 is the barrel grip version). These were the last Bosch electric jigsaws made in Switzerland. The current models I believe are of Asian manufacture.
I'd suggest to the OP to try to find out the UK 240V equivalent of these models.
Sal Bandini
As recently as 2014 the JS572 was made in Switzerland.
MoonRise
However the 160 is almost twice the price of the 150, which is still their second top of the line, is it worth that much more?
Rich
If the 160 has tool-less adjustment and the blade eject and the 'precision blade support' (or whatever Bosch is currently calling it) and the 150 does not have ALL those features, then yes IMNSHO get the 160 instead of the 150.
I'm pretty sure I have a 1590EVS. (no, I don't always remember all of the model numbers of all the various tools I have).
Back when I bought the jigsaw (in order to get a 'nice' jigsaw, instead of the annoying, LOUD, POS that just wouldn't die B&D consumer thing I had been using when forced to use a jigsaw), I looked online for reviews and recommendations. The Bosch 1590 (or the barrel-grip 1591) pretty much was THE saw to get.
So, I went to a store, looked at one and also saw its one-step-down 'brother' (don't remember the model number on that one). It felt solid, and looked almost like the big-brother 1590. Tool-less adjustment and tool-less blade changes, just didn't have the blade eject feature or the precision blade support (? maybe, or maybe not. It's been a few years). Was maybe $20 cheaper (maybe ~$140 vs ~$160 or so, back in the day ). Figured I'm not a production shop and can deal with changing a blade when I need to, so I bought the 'cheaper' Bosch.
Got it home, put a blade in, plugged it in, did a test cut. About 8000% better than my previous POS B&D monstrosity. Quiet, powerful, smooth. I'm liking this. Go to change the blade. Yes it was tool-less, but it was such a PITA that using a tool would have been sooo much better. IIRC, you had to lever up and then 'unscrew' the entire front top 'nose' of the handle grip area. Something like 20 complete turns. Then remove the blade, insert a new blade, and then screw the 'nose' back in. Another 20-something complete turns.
F-that. Cleaned the sawdust off the saw, put it back into the box, drove right back to the store (they had a 'Try it and return it if you don't like it' policy), returned it and bought the 1590 (I'm pretty sure that is the model I have and ended up with).
Got home, put a blade in (flick the lever, old blade 'shoots' out, insert new blade, done), do a test cut. Even better than its 'little brother' Bosch. Smooth, quiet, powerful. All the tool-less adjustments (pretty much just the angle on the base shoe) were even smoother and easier to do than on the one-step-down Bosch.
And the blade eject? OMG. Thought it didn't matter and thought I wouldn't need or want it. I was wrong. The blade eject feature is so nice, I changed blades for a few minutes. Just because. If you had to deal with a just used hot blade and wanted to continue working, no problem. Just eject the hot blade (just watch where it 'shoots' out to, it kicks out pretty well), no touching or grabbing or anything needed, insert new blade, and back to work.
So, yes you WANT the Bosch jigsaw with the blade eject feature.
The rest of the saw is really-really nice too. :thumbup: Did I mention smooth, quiet, and powerful yet? :spit:
atun
i think Bosch has been the gold standard for jigsaws for a long time.
engineer2
Chicago burbs
I have a high-end Bosch jigsaw and it is great, but the blade change is fussy. It's a non-issue on the newer models because they totally changed the design.
I now use and love my Makita cordless jigsaw and plan to sell the Bosch.
Wamsutta
Amarillo, Texas
Ok, an overwhelming vote towards Bosch then! I was looking at this one;
https://www.bosch-professional.com/gb/en/gst-150-bce-23294-ocs-p/
but judging by the recommendations for top of the range/blade support, that would give me this one;
https://www.bosch-professional.com/gb/en/gst-160-bce-34004-ocs-p/
Rich
I'd recommend the barrel grip for better hand coordination and control. If you ever need to saw upside down, it'll be much easier to hold.
https://www.bosch-professional.com/gb/en/gst-160-ce-34003-ocs-p/
PJNJ
Iowa
Around 10 years ago, I bought the top Bosch. Used it pretty heavily for a few years and was truly impressed with how good it was compared to the cheaper jig saws I had used over the years. It cost about $160 at HD. About 3 years ago, it dropped off my p/up tailgate while I was setting up a cut. It landed in the perfect spot to crack the nose. I immediately went straight to HD and got another one without hesitation. I can't recommend it enough.
:beer:
dnschmidt
Phoenix, AZ
Everybody has one tool that they make that makes their company. Skil has the model 77 worm drive. Black and Decker had the Holegun. Metabo has grinders. Milwaukee has the Sawsall. Bosch is the king of sabre saws. THAT'S JUST THE WAY IT IS!
Git
S Cal
I personally prefer the 'barrel grip' because for me it feels like it gives me more control
I have the older Festool Trion - which I feel was worth the money. They are currently selling for around $250. (I have heard a lot of negatives about their newer model - the Carvex)
https://www.amazon.com/dp/B004REJ678/?tag=atomicindus08-20
I am a big fan of Bosch and I would suggest as you go further in your woodworking tool collection you probably are going to eventually purchase a 'dust extractor'? The reason why I bring this up is Bosch has sort of copied Festool with their "Systainers" - Bosch has their "L Boxes" that will clip together and even clip on to the top of their dust extractors like the Festool System does
If your looking at going down the road - check out the Bosch Bosch JS572EBL. It has the barrel grip, some bells and whistles (led lights, dust blower) and comes with an L Box
https://www.amazon.com/dp/B008ELM9BU/?tag=atomicindus08-20
ca90ss
California
There were problems with the first model of Carvex, the ps400 and psb400 but those were replaced by the ps420 and psb420 which seem to get better reviews.
I went with the ps420 mostly due to it having better blade visibility than the Trion.
Tejaas
TX Hill Country
She's a beast!
That's what i keep hearing...
There is a used equipment shop near me that has this exact Dewalt jigsaw for sale at $75 bucks and looks to be in great condition.
I am debating asking them if they will trade it to me for a (like new, minus the battery) spare Dewalt 18V XRP circular saw that i have, complete with a hardcase.
It was free to me, and i planned to use it to rip aluminum - I just never seemed to actually use it.
It would be cool to turn a tool i don't use into a tool i CAN use.
Plus, I'd love to finally replace my ~20 year old Craftsman jigsaw.
~Tejaas~
PureLeaf
I have 2 of the Metabos. On both of them, the selector for the orbital action which is supposed to stay in place via a ball detent will vibrate out of place. So if you had it at zero, it'll end up at 5 just through vibration while cutting. This is really annoying. I've contacted Metabo about it twice, and never heard a word back. Other than that, it cuts. So if you don't mind it changing settings on you then go for it. Otherwise I'd look at something else.
That switch is a constant source of annoyance for me.
drtyler
Hard to go wrong with the Bosch jigsaw.
I've got the barrel grip version (made in Switzerland), but the top handle version is fine too.
R
Rich.
Newcastle, Uk
Very interesting, thanks for all the input from everyone!
Yep, im sure dist extraction will be on the list so thats good to know. Are there adapters available to use between different companies tools? Like say my Milwaukee circular saw for example?
I have to admit, i've never used a barrel grip, a jigsaw for me has always been a top handle and thats what i think im most comfortable with. I'll probably get a top handle and being a tool ***** like most on here i'll pick up a barrel grip at a later date if i feel the need arises.
Rich
tarbellb
Oregon
I have a old, bought used Metabo jigsaw that I got at a auction. Varible speed, barrel grip, stupid simple blade retainer.
IT IS SO SMOOTH.
That being said, a Swiss made Bosch will likely give very similar results. I would opt for a LED light if possible.
