Has anyone used this light?
383
Harrisonburg, VA
I found a light online that looks like it would be perfect for my basement, but have only found one source and no reviews. It is a surface mount LED that mounts to a J box, and looks like a recessed light.
Has anyone used this light, or know of anything similar? I don't have the height for a traditional can, this light looks perfect for my use.
https://goo.io/nJwYmJ
cybrdyke
USA
These are really popular in new home construction and even some light commercial construction. Very convenient. All the large, well known manufacturers make a version of this. The one in your link is a cheaper, DIY, no-name version, but that doesn't mean it wont suit your needs.
For comparison, a 60w incandescent bulb delivers 800 lumens. This one is 570 of LED, so probably very similar in output.
You will likely find a name brand at the local big box store or an electrical supply house.
Good luck,
CD
Rookie2
Western Pa.
I put one in for a friend, you need a shoehorn or a BFH to get the guts into an older electrical box. You may need to use a new box.
tyme2par4
NH
Can you elaborate? I just installed a similar LED flush mount fixture and it was just like any other fixture with just 2 wires coming out of it.
Falcon67
Merkel, TX
There are a bunch of these $25 units at our local Sams. Not as thin as the OPs post, but not very thick. Put in her big closet, lots of light. Mounted right to the ceiling box, 3 wires. Light weight and a bit flimsy but it works. The shade part unscrews from the base, have to be careful not to crush it with your mighty forearms.
http://www.samsclub.com/sams/led-pu...00000681846&adid=22222222627000041644&veh=sem
Rookie2
Western Pa.
This one had a transformer or power supply on the under side that fit up into the electrical box and used a strap that held the unit up flush.
reader2580
Minneapolis, MN
Home Depot and Lowes both sell versions of a 6" light like this for about $20. They are sold under house brands rather than a real name brand.
