Ryobi One+
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
Agreed!
I got mine because it was the only 18V cordless multitool at the time...Ridgid only had the 12V, Milwaukee didnt even have one, etc.
Have to say its been impressive everytime I use it. Even with the larger capacity pack, the convenience of cordless has far outweighed the weight and size.
I have a Fein for corded use, but for a quick job or if Im not very close to an outlet, the Ryobi gets used every time.
Once you get the 18v multitool, pick up the Ridgid Job Plus attachments that you can use. They are very handy. - Paul
dodge610
North Canton Ohio
Dodge, please report back on how good the sound is on the new stereo radio above. I have the fan and like it alot. - Paul
Paul radio sounds pretty good was surprised at the sound and clarity better than my C3 radio that i got years ago.Worth the money in my opinion.
jd_1138
NE Ohio
Was wondering if the lithium ion + batterys are worth the expense is there that much difference?
If you have plenty of ni-cads that are working fine, I'd say wait. But in theory the lithium batteries are more powerful and thus the tools should be more powerful.
Cheapest way to pick up the new lithium batteries is to buy a new tool(s) from Ryobi, and it will come with 1 to 3 batteries. There are so many tools in their lineup that it should be easy to find at least one that you need.
dodge610
North Canton Ohio
I have the lith ion batterys just wondered if the lithium plus were that much better and got more tools than batterys
jd_1138
NE Ohio
I think the biggest advantage of the lithium battery is that it's lighter and holds a charge longer. They say that lithiums make the tools more powerful, but the voltage is the same, so that's probably not true.
pauls_workshop
The Lithium and especially Lithium + are more powerful. They have a faster energy discarge rate, so when you go full throttle it does provide more power to the tool. It is more than just voltage and more than just current. You have to look at the amp-hours. - Paul
dodge610
North Canton Ohio
Thanks Dodge. The Lithum + are the ONLY Ryobi batteries I will buy now, period. They are head and shoulders better than the old normal Lithium. - Paul
Thank you paul think i will order a couple have a few outside summer improvments that i am working on. Less battery changes that way get the jobs done quicker.
dodge610
North Canton Ohio
Going to pick up the lithum+ batterys you convinced me to try them out. HD had them in stock.
jd_1138
NE Ohio
I never tried the lithium+'s. I sold all my Ryobi One tools to a disabled friend (PTSD) who started a light remodeling biz. He already had Ryobi One.
I had 4 of the regular lithium batteries (compact ones). I may buy some Ryobi again and then be in the DeWalt/Ryobi cordless worlds. I am corded now -- Makita sawzall, Ryobi multi-tool, older B&D jigsaw. Cordless for my impact driver, drill, and lanterns (DeWalt).
I'll try the lithium+ batteries when I get some more Ryobi tools. Their lineup is so complete and not pricey. I like their little green jobsite radio with bluetooth.
pauls_workshop
The Lithium + are all 4 amp hour. Two ways to think about that. First is if the tool isn't demanding much current, the battery will last a long long time before needing a recharge. If the tool is a high draw tool, then you see a performance benefit, probably 20-30% or so over the regular lithium. The 4 amp hours are competitive with *any* brand of premium batteries out there and really transforms all the tools to be much better than before. The best ones are the full size ones, but having a few half size is a great idea as they are light weight. - Paul
dodge610
North Canton Ohio
b62499770fa7f17c53f446896f8724cf.jpgGot them even had a chance to try one out I can see the difference. Had to cut two 4 by 4 fence posts off at ground level cut right thru them with the sawzall.
crice63
Lafayette, LA
I lucked into some returned sets cheap--don't know why they were open box but they have all been so great that I've bought other tools on the platform. The 1/4" impact wrench has been the most pleasant surprise. I can do all four wheels off and on the El Camino, and quite a bit of fastening, on one battery no problem. I also have the drill, sawzall, circular saw, jigsaw, orbital buffer, trimmer, and a couple of flashlights. The only disappointment was the 18 v leaf blower. It lacked any useful power. Local HD didn't have any larger Ryobi tools so I went with the Dewalt 40v blower. The Ryobi Lithium+ batteries charge quickly and last well. Almost two years on my 3 batteries in rotation and they seem not to have lost much capacity if any. I used the sawzall to cut a hole out of the top of a propane tank--the typical size tank for your grill--then cut the top quarter off (making a small forge). Cut through a couple 1/8" plates, some 2" fence post pipe, all on one battery. I've been very happy with the system so far.
Oh--the trimmer line refills are expensive, so it's better to roll your own. It also lacks the umph to edge our snaky st Augustine grass very well. I was hoping Dewalt would have a version for their larger battery but I haven't seen it yet. For regular trimming needs it is great.
dodge610
North Canton Ohio
0f6f20f347e21fac6280a2d2d07f987f.jpgAnother new addition to the ryobi platform most of the reviews were good on the jigsaw. Putting new deck on house and needed it so bit the bullet.
chrisexv6
CT
Just used my first AirStrike today...picked up the 16 ga nailer last week.
Have to say...quite impressed. Yes its a bit expensive for tools from Ryobi-land, but it feels quality and worked great. A little heavy with the battery (of course) but it beat getting hoses and a compressor out.
dodge610
North Canton Ohio
Yes some of the Ryobi stuff is a little pricey. But so far am quite impressed and pleased with the performance of there tools. Everything i put them thru they do the job and have had zero issue with any of the tools i have purchased.
dodge610
North Canton Ohio
Noticed it has a 4.4 star rating on the reviews. thinking about adding it on the platform today bot not till i hear from the GJrs.
pauls_workshop
Best way to get the tools cheaper is wait a few years after the model comes out, then try to find it at 1) garage sales or 2) Ebay. A little used will depreciate them nicely like most things. The older Blue tools are all very good still. Ryobi only very gradually puts improvements in the newer models, like 10% better here or there.
My newest automobile is a 2000, which I got back in 2007. I've spent a total of about $15,000 for our 3 vehicles and maintainance for my wife and I for the last 10 years. I don't often buy new tools either, or anything else for that matter! :rocker: - Paul
maxpower_hd
Massachusetts
Not that it is related but I wouldn't be storing that on top of my nicely painted motorcycle even for a photo op. LOL
You made me cringe as soon as I saw the photo. LOL
jd_1138
NE Ohio
Beautiful new Ryobi chop saw. That will come in handy on a lot of projects. I had to use an old fashioned miter box to cut some 45's for some door trim. I should've just did a flat piece on top with the side pieces butted up against it. :)
Chop saws come in handy and are way nicer to use than a circular saw. I was out in California helping my mom fix up her new (old) house. Neighbor guy (retired contractor) brought over a Bosch chop saw for me to use. I used the hell out of it, and I went to give it back and he said "I have 3 more, so that one is yours now". It's in her shed.
phule
Just came back from Home Depot found this Ryobi I lit in clearance. Listed for 229. How do these compare to Harbor Freight Bauer line? I just picked up a Bauer drill to do some around the house stuff during my Newley acquired free time. Never one to pass up a deal. I was looking at buying 2 more Bauer tools & a larger battery. Puts my total at about 199. Seems like a no brainer to go with a name brand Ryobi especially with a 3 year warranty. 0b1d02a8072182f35d4f801bfddb16f2.jpg
greg13
Weedsport, NY
I have been a Ryobi fan for years, but I am starting to switch over to 20v Dewalt. The major reason is that I have gone through 3 chargers in the last 2 years and Home Depot does not want to stand behind them, they want me to go through Ryobi warranty. They are the EXCLUSIVE seller in the U.S. they need to stand behind the product also.
tarbellb
Oregon
As of right now (2/21/20) Ryobi is better then HF Bauer, why, Ryobi has proven it will support its battery platform and keeps putting out quality products for 10+yrs now.
If or when HF has a battery platform worth buying that endures the market for 5+ years then we can have a convo on if it compares to Ryobi, Dewalt, Milwaukee, Makita, Hitachi (Metabo), etc...
drivesitfar
I love my Ryobi 18v tools. I've had them since the blue ones that I think came out on the market with terrible batteries in 2004 or about then and now the newer much better batteries can be used in my old Ryobi tools as well as the newer greenish yellow ones.
anybody else tried the blower yet? it's lightweight and does a decent job too.
PugetDude
Superstition Mountains, AZ
Drives, ^^this mirrors my experience exactly.
I have the bigger Ryobi cordless blower, it's great for blowing out the shop; really like the variable speed control. Makes it easy to blow off the bench or clean out corners using short low-velocity bursts that don't blow everything everywhere. I use it on the table saw and miter saw every time I use them; before I roll them back into the garage.
It's not a backpack blower by any means, but it's more than adequate and a lot handier for shop use. I use it occasionally in the yard for a quick clean -up when I don't want to fire up the Stihl Combi blower.
Recommended! :thumbup:
ptgarcia
Alta Loma, CA
I have the little lunch box style shop vac and it works great, especially since I only paid $99 for it with (2) 3.0Ah HP+ batteries and charger and storage bag. It's not perfect by any means, but I'd buy it again. I also have the One+ 22" hedge trimmer, and it's performance is on par with expectations as well.
techieman33
Kansas
I just got the vacs big brother the 6 gallon for $52. It has great suction. It doesn't seem to be built very tough though. Fine for around the house stuff, but it wouldn't stand up to being thrown around on a job site. The hose especially seems really cheap.
drivesitfar
PT: I also like and use the Ryobi hedge trimmer.
ALL: I love the Ryobi 18v chain saw and I own 3 of them cause with a sharp chain they can cut almost any size branch or tree or lumber.
PugetDude
Dodge, please give us all a review of the cordless miter saw once you've used it a while! Just how good is it? - Paul
Paul, here's an unsolicited review:
I had one and gave it away after a few months. It was underpowered and too small to use for anything over 1x stock, IMO. Had to change batteries way too frequently. $29 on clearance at HD, so I wasn't out much.
I've got a bunch of Ryobi 18V stuff, am generally happy with the tools, love the platform, but this and the dustbuster vac were the only two that I wasn't impressed with.
drivesitfar
I'll chime in on the Ryobi 18v miter saw and agree that it's light duty. it does cut the new almost balsa wood like 2x4's and 2x6's and maybe with a new diablo blade it might cut old wood. Really I only use it if it's a quick job or if an extension cord is too far from a plug cause i use my Makita or Dewalt miter saws if it's a more precise or heavy duty type job.
the Ryobi 18v skill saw and drill are light duty too, but the Ryobi 18v impact might be indestructible cause I've used the blue one for maybe 15 years and the yellow one for 5 a lot and they still work great.
sawsall is very handy, but if I have a lot of nails or steel to cut I pull out my corded Makita.
dodge610
North Canton Ohio
Used this miter saw to redo my deck last year worked flawlessly. Total cuts were around 800 o so all ways right on and never slowed down on me. this one tool alone sold me on the ryobi line. Have bought many other ryobi one tools and never looked back.
drivesitfar
Dodge: was your deck cedar and 5/4 x 1's or do tell? if that was the size i'd say the Ryobi 18v was the perfect tool if you had a nice blade on it.
ALL: anybody else have the Ryobi 18v chain saw? do you sharpen the chain yourself or have a shop do it? how do you like using it?
dodge610
North Canton Ohio
Drives no deck was not cedar mostly 6x1 treated lumber. I used the blade that came with it till it dulled out. Then bit the bullet got a Diablo blade for it. My deck goes haly way across the back of my split level. The other half has a florida room with sliding glass door into house.
