Weld Jig I just Finished
thaxboyd
Utah
Designed this table leg welding jig and just finished building it today. It rotates so they can weld both sides and I put jacks on all 4 corners so it won't roll away when they use it.
Whiskeymike
Austin, TX
Really cool. Would love to see a walk through or write up on the parts you used and why you used them. I wish there were more books available about this kind of stuff.
catalytic
Boston, Los Angeles, Cleveland
Awesome. If it were mine, I would consider some kind of simple lockout button/valve/pedal so stuff can't move accidentally (while in the middle of a weld) if you bump into a control lever.
Would you mind sharing where you sourced the components, or any details of what components you used?
LXCam
Damn fine job OP! I'd be showing that off as well. I hope your talent is appreciated by your company since it's pretty rare anymore to find someone who can think through the process and build something like that.
I always enjoy making jigs more than I do producing with them.
I'm the same way. I have / had several products that were very specialized low volume stuff. Some welded, fabbed or machined. I got off on creating the most efficient way of making or assembling it. But once I got it down to a science, I completely lose interest in doing the production work. I'll normally make the first run or two of whatever in house, then hand everything over to a job shop so I don't burn out.
tarbellb
Oregon
Damn! That is a nice jig, work of art in itself.
I to would like to see the product being made from the jig.
Thanks for sharing.
Kracin
Omaha, NE
looks a lot like the welding tables we have for production robots where i work. cool stuff.
whats this jig meant to be used for making?
T
thaxboyd
Utah
Thanks for sharing.
Nice! Details please on the locking jacks.
I will post up some pictures of the legs that will be welded on this jig... There is no demand for them yet but there will be very soon.
The cylinders on the rotating jig are from PHD... Only picked that brand because I like the local rep and they supply models on their site to make the design go easier (most companies do though)
The rack and pinion unit that rotates it was sourced from McMaster Carr
Here is a link to more detailed pictures... https://goo.gl/photos/r7iGqab99q1izTsYA
Let me know if you all want more details or have any other questions
T
thaxboyd
Utah
Here is another one I did... This machine bend, cuts and crimps in 2 cycles.
