Electrical: Drilling around obstruction
tearapin
I am adding an extra outlet. I have to traverse tow vertical studs. Between the two studs (unfortunately) is my air conditioner line. The line that carries the Freon I think. Copper tubing and another thicker line wrapped in padding.
Anyway, obviously I do not want to puncture that when drilling the stud. I am thinking of using a piece of conduit to snake the drill bit down. So in essence I would be drilling inside the conduit. I am only running Romex. The conduit would be just for the drilling part.
However, anyone have a better trick?
Fixin'Stuff
HotterNHellHouston
Can't think of a better solution offhand, but here's a safety tip: Be sure to wear heavy, leather gloves and a full face shield while doing the work. Refrigerant escaping from a decent sized leak can instantly freeze skin, eyeballs, etc. before you can react and pull away. One nick in the line could really ruin your day. :eek:
-Brent-
Utah
Is this something you're drilling blind? If exposed I don't see any issues since you can see where your drill is going.
That said, I would open up the wall and patch it when you're done. It's easier and cheaper than dealing with broken AC lines.
T
tearapin
I think I can reach back there and feel the AC line. Then place the pipe and drill through the pipe.
T
tearapin
Can you post a picture of your work area?
I could but I do not see how that would help. It is a blank piece of drywall.
It goes like this
switchbox...stud...air conditioner line...stud...additional added outlet.
Cobra5150
GA
Google Versibit.
You can get a placement tool to help control it
-Brent-
Utah
Just cut the drywall, drill, run wire and patch (you might have to put a couple wood strips for backers to mount the patch, depending how/where you cut it). Seriously, it's not a big project doing it the right way.
joe_padavano
Northern VA
^^^THIS!!
You can also use these clips to hold the patch in place:
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Cut the drywall stud to stud and high enough to work comfortably. IIRC, Lowes sells 2'x2' pieces of drywall in case you would happen to ruin the piece you cut out. Cutting it out would be by far the easiest to do to insure you don't tear up a Freon line.
T
tearapin
Cutting it is fine except the drywall is not painted and the patch would look like poop. But I see your points. I may go that way if I cannot get my arm in the to positively feel where the pipe and bit are going.
One simple outlet, a major PITA.
wasfuzz
Mn
This would give you a reason to paint it and finish it right!:dunno:
Crazyjake8493
Upstate NY
Is this in a house or garage? Attic above or basement below the wire could be run to and then back up/down the stud bay to the new outlet?
