CrotalusAtrox
Wow on a great find but holy sh...t on the paint, must of been on mushrooms when they did that
Very interesting. I wonder what the max clamp force rating on that is, seeing as how it is a full weldment.
Finished up the Versa painted it red for Independence day I didn't have white and blue. These vises are pretty well made.[/URL][/IMG]![]()
---I just wonder what these GJ members will come up with next.Chilang, that Versa looks great in "arrest me red"
Royce, that is one for the "Vice stand thread"!![]()
Royce, I believe I would leave that as is.---That makes a unique vise tree.---That gives you bragging rights.---I just wonder what these GJ members will come up with next.
Outlawmws FMC1959 Thanks guys, the reds official name is Sunrise Red but if you paint a fast enough car with that color I am sure it will get you arrested.
Royce If you are ever under motor attack you have a place to hide that thing is a beast.
Royce, I just had a thought, you need a nice slow gear reductions motor ad a ring gear, and a switch, and then it can be power rotated to position!
Thanks drives,
Here is the other one.
Royce
Great vision!Hello
what brand this vice?
thank you
Gilll,
I use the term embellishment to refer to the raised letters & images on the castings. Embossments and cast markings are other terms with the same meaning.
I thought I should post a follow up to the post asking how to remove the dynamic jaw in a Wilton C5. I finally just kept turning the screw forcibly until it came out. Turns out some hack had put it together with a single 1/4" rod all the way through the main nut. It must have been 10" long. when the jaw was closed it mangled the rod and damaged the threads. The rod was then cut flush at both ends. Luckily, the rod was softer than the threaded rod and I was able to clean up the threads and make everything work great. I would assume the same hack filed off the teeth from the locking ring and then having realized his error, added brazing to the top to get a friction surface. I'll figure out how to address that when the weather cools a bit. Average high now is in the high 90s. Here in east Texas the humidity remains very high and the temps don't drop much at night. As a new Texan it may take me a while to acclimate.
Hello
the Jaws measure 125 mm.the vice weighs 37 kg
it measures 50 cm in length to 27 cm high
I live in France
thank you
as far as value since most of us are located in different parts of the world you might want to post up your vise on this thread and see if the members in your area might have a better idea of the maker and the value then report back to us if you find out. OK? good luck and i have seen plenty of vises similar to yours but can't recall the bird on top of a MW yet.
