jbmatth
House looks great and the spray foam will be awesome when the utility bills come due. The work sites for the stone on the house and garage were very tidy by the end, I'm surprised at how clean it is.
JB
JB
Thanks for checking in!Wow! Everything is looking amazing!
Thank you!Really nice property! Looks like you are doing it up right. Congrats.
Its already awesome. 90 the other day outside and it was 75 on the first floor with no doors on the garage or drywall. Cant wait to see how cool it is once its sealed up. We have it in our shop now, its awesome! They cleaned up a majority. I spent another hour picking up the remaining brick and moving it around back of the house for now.House looks great and the spray foam will be awesome when the utility bills come due. The work sites for the stone on the house and garage were very tidy by the end, I'm surprised at how clean it is.
JB
Thanks! Stay tuned much more to come!Holy ****! Stonework changed everything from awesome to friggin incredible! !
I have a new favorite shop!![]()
Thank you very much! The additional cost will pay for itself within a few years. Its really worth it with the new energy codes that are in effect. Flash coat of closed cell with batts behind it used to be the way to go. I'm now convinced open cell in the entire cavity is much more efficient. I have closed cell on my basement walls and the shop will be closed cell as well.Looking real good. I like the colors on the shop building a lot. Just had the closed cell foam done on my shop and all ready love it. Wish I went with the open cell foam in my house. My GC recommended against it, ended up kicking him off the jobsite and wish I went with the foam. Too late now. But your House and Shop are coming along very nicely.
UnionMan
Yea 4 pieces that all snap together. Its pretty neat. Same wrap fits 8/6/4" columns. Then a trim rings goes on the top and bottom. I think they were around $80 each. The ones for my front porch are going on tomorrow hopefully.Were the porch columns wrapped with PVC?
Custom Mouldings made the house columns i will have see if i can find out who made the ones for the pole barn. It doesnt say on the receipt. I got them from Railing & Building Products in Greenwood, DE.Do you by chance have any more info on those column wraps? I have a few that need to be covered and like the sounds of that vs gluing PVC pieces. It's worth a look anyhow.
Thank you for the compliment.Congrats dude, looks awesome.
Thank you. I'm doing a closed loop system. The company i use for all of my HVAC and plumbing doesn't even do geothermal systems. They hire another company to run the loops to the units and hook it up. I will be doing the digging with my own machines. I have 2.5 ton unit downstairs and 1.5 up. So its 800 ft of loop per ton or 3,200 feet. I have plenty of room and very good soils. Loops go about 4' in the ground. My parents have a pump and dump which was installed in 1991 and still works good. They replaced there units a few years ago for more efficient ones and replace there well pump for a constant pressure variable speed unit a few weeks ago. From what i've heard closed loops are the way to go if you can do it. My parents have two wells in there front yard. One is capped below grade so you can't tell. There is also a 30% tax rebate if you install it before the end of the year.Wow very nice build. Count me jealous.
What are your plans for the geothermal? I'm looking at options to replace our air source heat pump in Maryland and one place is proposing an earthlinked DX system. Leaning more toward closed loop water since I have a small-ish backhoe to dig it but the silt/clay/sand in the area requires a pretty long loop.
First floor and basement is combination heat pump and air handler. It also has 10k electric backup heat. the second floor the heat pump sits in the basement and the air handler and 10k heat sit in my mechanical room on the second floor. I did have to run freon lines from the basement to the second floor and install an emergency drain pan. They won't let you run open duct in the walls anymore in delaware so that why the air handler is on the second floor with the duct work running above.Maryland actually has an 1800 utility credit, 3k with the state and a property tax credit up to 3k in addition to the fed 30% which has me intrigued. Are you going to run two separate heat pumps or one heat pump feeding two air handlers?
I'm being quoted 1200 ft per ton (4 tons) for 40 degree min loop temp or 1700 ft per ton 44 degree min temp in damp silt/clay. I'll have to get creative fitting either on a wooded 1 acre lot.
Yes i believe thats how they are going to do it. One pipe in and out for each unit. I wanted to get the drywall finished and the garage doors on before i set the units, or left anything of value in the house. I've never seen one of these units installed only what i've seen in pictures. Like i said the HVAC company i use doesn't do geothermal so they bring in another company that specializes in this type of application to run the loops and make the connections.Good info on the geothermal. With only 4 pipes through the wall, I'm assuming your manifolds are buried and it's two independent loops for the two systems?
Your pole building fits right in next to the house!
It looks like PVC in the wall. Thought they typically fusion weld HDPE until inside, but I guess there's lots of ways to do it. As long as it doesn't leak!Yes i believe thats how they are going to do it. One pipe in and out for each unit. I wanted to get the drywall finished and the garage doors on before i set the units, or left anything of value in the house. I've never seen one of these units installed only what i've seen in pictures. Like i said the HVAC company i use doesn't do geothermal so they bring in another company that specializes in this type of application to run the loops and make the connections.
They are just sleeves so i can get the pipes from outside to inside. This room has drywall on it now. The HDPE will slip through the 2" sleeves in the wall.It looks like PVC in the wall. Thought they typically fusion weld HDPE until inside, but I guess there's lots of ways to do it. As long as it doesn't leak!
Thank you!Nice looking place you've built.
Thank you!Lovin that stone work! Looks great!![]()
They have been backordered for a month. Waiting on flush mount LEDs in 4.000K. I had some in 3,000K but i wasnt crazy about the color output. I need to get the 6" recessed LEDs mounted on the front and rear porch now that the ceilings are done. All of the lights outside will be in the 4-5,000K color range. The shop and garage lights will be 4,000K and ill go with something around 3,500K inside the house.I am looking forward to seeing a picture at dusk when you get the soffit lights completed. I am thinking about putting them in next summer when we finish our house.
Levi
Thank you!Looks awesome
Thank you! More to come!Really really nice!!
Thanks buddy stop by one night and drink a beer with me! Im doing 2" of closed cell spray foam on the walls. The ceiling under the floor with be R-38 batts and the rest will be blown in after the ceiling is up.Looking great! You probably mentioned previously but what insulation are you using in the shop?
Thank you!Looking good.
Does your ceiling have the reflective film between the metal and the roof purlins? If not you will need a vapor barrier. Are you going to blow in insulation in the attic or use fiberglass batts? You could always do open cell spray foam on the underside of the roof metal and everything would be conditioned if you dont have a vapor barrier. I did that on my house.I definitely will swing by one of these days. Thought you were doing the closed cell just couldn't remember. I just had my walls sprayed with the closed cell a few weeks ago. Now trying to figure out if I need vapor barrier on walls / ceiling then I'll be ready to button it up.
You wont need a vapor barrier on the walls if you used the closed cell spray foam. Did you decide on metal for the roof and walls or OSB?
No vapor barrier needed then. Stop out on Saturday if you're in the area.Yeah between roof purlins and metal is the thin plastic insulation, double bouble I think they called it. Planning to use blow in in the attic. Walls have 2" closed cell. From the research I've done don't think I need vapor barrier on the ceiling.
Going to go with OSB on the walls and still on the fence about the ceiling at the moment.
