I moved to a new house and need to get my compressor up and running again. I have an existing out I believe to be dedicated. Its currently on a tandem 20 amp breaker and I want to move it over to a new double pole 20 amp for my compressor. (I have space in my panel)
I turned off the breaker and checked every light/outlet in my house and the only one without power is the outlet I believe to be the dedicated outlet.
This outlet is also roughly 2 feet away from another outlet giving me another reason to believe its dedicated. Just above it is the central vac that was plugged into it. The reason I have not done this is because its labeled as bathroom receptacle which it is not as I tested all of them.
What say you? Is it safe to rewire it?
I've attached the outlet in question.
