malbojah
So I have this old Coats RC-20 tire machine I bought to change my motorcycle tires with
(yes, I've already changed out the PVC air lines that worked fine for a decade with copper. This is an old pic)
I've gone through and replaced everything that leaked air (rotary coupling, turntable cylinder, hoses in general) but I'm stuck with the bead breaking cylinder. I've replaced the seals, but there are a pair of pin hole leaks on the mounting ears
I have choices here:
1) leave it be and live with the air leak,
2) 2-part epoxy it and hope it holds
3) weld it (it is a steel cylinder, not aluminium)
4) maybe find a used cylinder on ebay
As much as I would love to weld it (I do have a mig welder), I'm also aware of the dangers of fvcking with air cylinders and changing the steel temperament.
Something tells me it will either be option 1 or 2
