Rain down spouts ??
1jjpop
Central Iowa
I have the regular [small type] down spouts on my gutters on my house . I see people putting bigger ones on there drains . Do they really help?? Seems like I have to clean mine out ever fall. I have gutter covers on my eves.
cbusters
Trend in Florida for a while were different kinds of rain chains and other things instead of downspouts. Kind of cool looking when it rains.
Stuart in MN
Minneapolis
Bigger downspouts usually go with larger gutters. If yours are draining well as is, there's probably no reason to change them.
southalabama
Brewton AL
In south alabama it often rains so hard that one downspout can't handle it so then you get overflow and some backing up around the facia over the top of the gutter.
Options. What he said. Two.
Or bigger
A couple nice houses have copper chains and they look cool. I'm just not sure how well the work with hurricane winds.
Fixin'Stuff
HotterNHellHouston
In the Houston area we can get 15 inches of rain in 12 or so hours. Big downspouts are good when that is happening. The best thing I've found is that the big ones hardly ever get clogged with leaves. Everything just blasts through. :)
kbs2244
Go outside and check if they are overflowing during a real heavy rain.
CNGsaves
KS and OK
^ ^ ^ ^ This. Never, EVER, NEVER just put in 2"x3" downspouts. Upgrade to at least 3"x4".
toolmiser
La Crosse, WI
Here is something I did. I have a place where there is a lot of volume flowing thru it on occasions even with the large downspout. I drilled a few holes near the top of the "cap" to allow the overflow to escape on that end. It's located away from the above grade foundation that has no basement.
