Pathfinders
Upstate SC
Had to take about half the bike apart to chase down a electrical problem. Got pissed off when I started pulling covers off. The PO had added a lot of electrical stuff. I cut it all out and returned the bike to stock.
Went for my first ride this year, 96 miles on back roads. Still got a little grin.
rt dak
Putnam County, NY
Front brakes on the Ram and shined up the Dakota
Finky198
North East
Awesome truck!!!! My father had a green 5.2L, so I'm kind partial to the dakota :evil: and now I have a 1998 Jeep GC with the 5.9L.... :3gears: What have you done to it? looks lowered? looks like fun brings back memories....
Heres my jeep
Xicaque
I move every 2.5-3 yrs. No choice.
That's awesome! I hate it when some riders add so much **** and the wiring is a mess:3gears:
rayra
Escaped from Los Angeles
Woodworking, #147 in a series, More 'Jake's Chair' Adirondacks
The chair blueprints are available on the interwebthingy, called 'Jake's Chair'. It's a modified adirondack design. It's a bit larger and a good bit more upright than a typical low-slung northeastern adirondack. Folks with lower back pain often have trouble with the traditional designs. It also has wide flat level armrests - which I've widened even more - which readily hold a dinner plate. I've also added a built-in beer / cup-holder in both arms.
So the neighbors hit me up for a pair. A cost plus cold beer deal. $110 for lumber. I've got a partial 5# box of 1-1/4# plated screws laying around, as well as some latex primer. If one were to start with no materials, retail cost would be about $80 for materials. Takes (5) 1"x8"x8' and (1) 1"x6"x8' with very little remainder. After some experimentation with layout I got things condensed as tightly as possible.
Take some care in wood selection and placement of your cuts, avoid knots in the seat slats, especially at the peak front area where everybody perches. The slats are only 1-1/2" wide so a knot destroys their strength. I sometimes built them with hardwood slats in that area, if they're being painted. I've also rebuilt my own with a wider curved backbrace, also of hardwood, after its mountings failed at around the 3yr mark.
I'm doing much of the work as batch processes. I traced the patterns in pairs. I arranged my cutting layouts so I can chop the full planks down to more manageable pieces. Then I ran what I could thru the table saw, mostly the straight slats, backrest staves, the major leg and armrest supports.
Then it was on to the bandsaw for a rough-cut pass, basically breaking down all the pieces from the traced planks. Then a second pass cutting closer to the traced lines to get rid of as much of the waste as possible.
On to the big heavy table 12" disc sander, where I worked all the outside curves down to their lines. And hogged out as much of the inside curves as I could reach.
I'll use an oscillating orbital handheld disc sander to work most of the inside curves. Sure could use a table / drum sander. I might clamp the like pieces (4 of each in this build) and work them with a belt sander, too.
Have to get the neighbors to pick a pattern for the tops of the backrest pieces. A large continuous curve, a sharper parabola, a stair stepped design, or something similar in a sort of curved scallop-shell pattern. Sky's the limit really, as long as you make the backrest high enough that leaning your head back doesn't rub on the ends.
Also to that end, I run all the seat slats, backrest staves and the armrest flats thru my table router with a roundover bit, for comfort.
Time requirements are variable, depending on how much you want to fiddle with it. Minimum time is 3-4hrs.
And I'm building on my modified Ron Paulk design portable workbench. I chopped down my old rolling work table, re-worked its chassis to fit the new smaller overall size and lowered the height so the Paulk portable modules remain level with my table saw.
Scales
Left Coast
Cleaned off the workbench, again. And organized some pegboard hangers.
Still working on my socket holders and trying to decide what I need at arms length.
album-72157671771008655
PassnThru
Bowling Green KY
New fuel filter for the Explorer. I guess I should really go through the maintenance schedule - it was supposed to be done at 30K - not 90K :willy_nil
Anyhoo - some pretty nasty gas leaked out the inlet - cut the case off to see the filter.
kberjian
Calgary
With the space out here on our acreage I wanted to get a few play structures for the kids. I was pretty shocked at how expensive they are and how flimsy most pieces are. I decided to make a few pieces myself out of stock steel and leftover parts I have.
First one up was a teeter totter. Used some 2x3 tube with a 1x2 on it for stiffness for the main beam, dismantled two bikes from the junkyard for their handlebars and seats, and used the main steering bearings for the mid bearing on the teeter totter. One day of work later and it is ready for paint! I will be staking the four corners down into the grass when it is in position. Total cost was about 250$ including paint.
PS: disregard the booger welds on some parts, I was having welder issues..... I fixed the welder (gas flow in the hose) and ground down the welds before I put it all together.
Geek
8000'
Changed my diff oil in the jeep
Then re-lifted a buddy's jeep from 2.5 to 3.5 with high steer
.mobile
90zcar
I opened a box for a 1" dimple die I ordered from eBay only to find they sent me a 2"!!
90zcar
Yeah that's where they are originally made. These came from California. They seem very nice and have tight tolerances. Just got the wrong size lol
Worked on the "new" camp trailer to start getting a deck/rack up front to hold my cooler chest. once that's done, then I will make up a mount for the small Prop tank.
After I was done for the day I replaced the cord on one Milwaukee Portland, and replaced the plug on the other, as it was twist lock...
Outlander
Quebec, Canada
Went to the local hardware store (15 minute drive) for propane. Got home, wife had just broken the toilet handle. Went back to said hardware store for the part. Had to heat it up with the heat gun so I could manipulate the plastic into the right shape to work.
For some reason, I was a star in Mrs Outlander's eyes! :evil:
spent21
Franklin, Tn
I made a terrific mess.
But I did manage to build a bench for the wife. I bought her a storage cabinet to keep her gardening stuff on the patio. Even though I sealed the seams, it would pull water into some of the joints & rust. The new bench has enough storage to keep all her stuff in & provide some additional seating on the patio.
I'll get it painted & clean up the metal cabinet for repurpousing in the shop this weekend.
I also hung her barn door at the entry of our guest rooms
Finished the bench.
spent21
Franklin, Tn
We had a party in it. I had to move some stuff around, but cleaned up nice. Everyone had a good time & can't move.
60 burgers, 32 hotdogs, 120lb ice & twin lane slip 'n slide.
zak77
Monson, MA
My GF and i picked up a '96 4runner for her kid to drive as a first car so being 20 years old and having 225k on the clock, it needed a going through even though the previous owner took very good care of it. I figured it'd need some brake work done and some fluids changed so i got at it sunday morning. It didnt need the oil changed but figured i'd toss spark plugs in it. Well, first problem was that plug #2 came out with a heli-coil insert. The rest went great but i need to address that issue.
Pulled the front tires and brakes look GREAT!!! I bled them since the pedal felt spongy and got some air out of the system. Everything up front looks good and feels tight, sway bar bushings are cracked and showing their age. Otherwise i just cleaned things up and put it all back together. Next were rear brakes and knew they were gonna be an issue. Pulled the rear tires and new i had to R&R the bell crank adjusters, very well known issue on the taco's/4runner and tundras. The ones on there were absolutely seized solid, gotta order new ones. The shoes were about 50% gone so i'm just going to replace those while it's apart.
Rear diff oil got changed out also, looked good with some shavings on the magnet. Rear shocks need to be replaced to that's on the list. Greased the u-joints and checked for play, all good. Needs an exhaust hanger welded on but otherwise a very clean suv. Not bad for $2500.
Still need to change the ****** fluid and few other things but it looks pretty good so far. The frame's starting to rust but i'll spray some fluid film on it.
logan_gibson
Refinished a wheelbarrow someone was throwing out, I've got a new/better wheel for the front, but I've gotta make an axle for it or make a sleeve for the old one.
Also assembled my 3 1/2 vice I got for free, Still need to located a swivel clamp. Does anyone know if wiltonviseparts.net is a reliable source?
BleedingBlue
Indianapolis
I attempted to cut and install crown moulding for my basement columns. Of course my columns are way out of square so my ends line up terribly.
This is my first time doing crown molding and it is not fun haha
zmotorsports
Northern Utah
Didn't do much in the shop last night other than a BS session. I had a friend whom I met online and have communicated with many, many times via an rv forum, telephone and emails stop by. He is from North Carolina and was heading back home from an Alaska trip and decided to take a southern detour to meet up with me. Awesome night of BSing, comparing notes and hanging out in my shop. Great guy.
Mike.
JimVonBaden
Northern Virginia
JVB,
are you posting your XS400 build somewhere? Like at the XS400 forum? I'd like to see how you are coming along. I have a 1980 model that I restored to full stock. Thinking of looking for another one to make it into a cafe project.
Tell us more about those 25 pounds of washers... I thought I had a ton but you take the cake.
There and on ADVRider, full build thread on ADV: http://advrider.com/index.php?threads/1981-yamaha-xs400-scramblerized-eventually.1092208/
The 25 pounds of washers started as 50 pounds! :D
A friend gave me a box of them when his company, AOL was tossing out a couple of tons of unused hardware. I also got many pounds of nuts and bolts, and misc hardware.
Outlander
Quebec, Canada
phayzer5
Gainesville, FL
Re: What did you do "IN" your garage today?
Reassembled my new $5 toolbox after a quick repaint last week. Badge seems legit
