window sizes for my pole barn
Tarheel Slim
Nassagaweya Ont.
Hello ,im about to order some windows for my 30x44 pole barn and was wondering what size windows some of you guys used for your building,i have a 10ft wall height,2 windows going on one gable end, and 2 windows along one length of building,was going to go with a 24 H x 30 W or wise versa.Seems Home depot is cheaper than most other places i looked.
readhead
Durango, Co.
3020 is a pretty small window. Do you want light, ventilation or view? Have you bought the siding? If not and all you want is light I would recommend light panels mounted high on the walls. Is security an issue?
Pathfinders
Upstate SC
Great words of wisdom.
Toomanytools?
Washington
I was going with 3 wide x 18", but think I'll go with 3'w x 2' H. Setting top of window at 80". My thought with the 18" set at 80" was I could see out but it would be hard for someone to look in not so concerned with that now. My thought is a bit of light some ventilation and to look out. Also see a lot of 3x3, and 48" x 18" set higher up.
finn
The UP, God's country
Mine are 5'x5' , I think, on both my shop and garage.
The vinyl sliders let in a lot of light and we don't have much of a security problem up here.
JimH74
South Central Texas
I have six windows, all 36x48 purchased at HD. I enjoy the light in the cooler months, but in the hotter months, I cover them on the inside with reflective foam board. My biggest problem is that the guy that built my 30x40 red iron building apparently didn't install them correctly because i get water leaks around all 6 windows! Nobody around here wants to come and correct someone else's work.
