3/8 and 1/2 in preference
indestro
At what point do you decide to pull out the 1/2 in set as opposed to 3/8?
Danglerb
SoCal
I grab a ratchet that fits the job, then get the sockets that fit the ratchet.
rsanter
visalia ca
experience
how tight so I think the bolt is?
am I assembling it or breaking it down?
how much room do I have?
how much depth do I need?
bob
NeilH
UK
i only ever use 1/2 if my MG31 wont shift it. no matter what the size.
although, if its a 24mm suspension bolt thats been in there for 100,000 miles on a taxicab then ill break out the 1/2" 2135qti straight away.
its all relative.
cruiser808
Hawaii
As the others expressed, expirence. Probably at 5/8", but it depends on the status of the fastener and the manly man arms to complete the fundenmentals. dropping some kroil doesn't hurt too.
HandyManny
Out West
Use the correct size tool for the job. Use the following as a rule of thumb:
1. 1/4" drive tools, maximum fastener size is 1/4"
2. 3/8" drive tools, maximum fastener size is 1/2"
3. 1/2" drive tools, maximum fastener size is 5/8"
4. 3/4" drive tools, maximum fastener size is 1"
5. 1" drive tools, maximum fastener size is 1-1/2"
**Fastener size is thread diameter.
This general rule of thumb has always served me well.
I
indestro
Well,.. kinda like I thought experience and timing I suppose. Thanks for the support and KRUSTY could I get a hyperlink to that site you recommended?
HandyManny
Out West
Check my post above. If memory serves me well I believe I got that info from a Wright publication several years ago. At least I think it was from Wright.
joenero
north ca
This is a serious "you just know" deal isn't it?
3/8" is good for when for when whatever I'm doing used less than 65 ft lbs to be installed. Beyond that, I go for 1/2 inch. That's usually heavy duty R&R's, and suspension work though. Stuff where I'm guaranteed to be covered in grease.
krusty the clown
Member Emeritus
niangua, mo
i looked on the wright site and it has changed, i could not find it.
handymanny's figure's may be from the wright article, as remember they were surprisingly low for me.
Merkava_4
Clovis, CA.
It depends on how lazy I'm "fillin" that day. I've used a 1/2" ratchet to bust loose a spark plug on a Briggs & Stratton. :D
Fedwrench
Valley of the sun
For me 1/2 drive is used mainly for lug nuts, brake caliper cross over brackets, and cradle bolts. Pretty much everything else on my fleet vehicles is either 1/4 or 3/8 drive.:beer:
GDA
Dallas, Texas
1/4 drive up to 12mm in engine bay and interior
3/8 for 13 to 19mm
1/2 for over 19mm and....
3/4 drive for the big stuff
I will usually grab a 1/2 drive at 17mm and over when doing brake and suspension work. Most of the time and depending on access issues, I try to save my ratchets by using a 3/8 or 1/2 breaker bar when initially loosening a bolt thats 17mm and over.
HandyManny
Out West
It is one of those "you just know" type of things. The table I posted above was something I came across years ago and cliped it out to tape on a shelf above a workbench. Basically to point someone to in case they came asking for concrete reasons. I never really referenced it because experience points you in the right direction, usually. You're right, it's just one of those thing you kinda know.
rhandwor
These are good guides but I also look at the torque required like front wheel drive nuts big diameter but not a lot of torque. Wheels on large truck lug nuts are a lot tighter.
greenreese
65ft-lbs seems pretty spot on to me. That's about where I got for a 1/2in too.
ZRX61
Solar Blight Valley, SoCal
Maybe if you work on Marine engines, but those guidelines don't fly around aviation..
1loudsuv
I dunno ill say different but I bet we work on different things.
I use my 3/8 mg325 for everything up to 21mm. 99% of the time it loosens them without any struggle. (I know most caliper brakets I work on should be tourque around 80-100 and those are 18mm and I use the 3/8 impact)
I work in the automotive field.
HandyManny
Out West
Certified A/P mechanic as well as a Flight Engineer and ATP. Worked on them and flown them, both professionally. Pretty sure I know my way around the systems of a airplane. That guide applies to most powerplants and engines. No it isn't something I ever referenced much once I started wrenching, just always kept it around in case some newbie or some curious joe came asking general questions. I hate to be the type of guy who's answer to everything is uhhh I don't know. Someone here wanted to know, so I posted it. Even if some disagree. Then again your remark so far is the only contribution I've seen from you on this particular subject. Care to share something useful? Granted I will admit I haven't turned a wrench on an aircraft in over 30 years, and didn't do it very long back then either, but gee...:wtf:
Mr.Nutcase
USA
Is this a real question? 1/2 for heavy work(ie suspension/brakes/..... 3/8 for general work(engine)..... 1/4 for small stuff.(electrical, interior..
Moose-LandTran
The Brink of Insanity (England)
Just use whatever works and is comfortable for you to use. Obviously you don't use a long 1/2" ratchet to tighten 10mm nuts on battery terminals. Common sense/experice/whatever.
If it's really that hard to figure it out maybe you shouldn't be fixing cars, and your "skill set" is more suited to something like washing dishes. :rolleyes:
Mr.Nutcase
USA
Just use whatever works and is comfortable for you to use. Obviously you don't use a long 1/2" ratchet to tighten 10mm nuts on batter terminals. Common sense/experice/whatever.
He is right... Common sense/experice/whatever.....
and on cleaning dishes///
