Is this compressor worth the hassle?
G-Ram
NWO
I picked this compressor from a buddy for a case of beer. Everything appears to be in good physical condition. The only issue is that the compressor itself only pumps on one side. I can put my hand over the outlet and spin it over, the one stroke will blow my hand right off. Spin it over more, nothing at all comes out on the second stroke. I figure the tank alone is worth it for what I paid. Is it worth my time to pull the compressor apart? Or just buy a new one and be done with it?
Jim Johnstone
Brantford, Ontario
Let's see some details on the pump. Tank and motor won't help us decide if the pump is worth a rebuild. Odds are if it pumps on one side and not on the other, it's probably just a valve job needed. So depending on the brand, it may be simple and relatively inexpensive or could be a hard to find item.
fatfillup
Finksburg, Md
Compressors have check valves of some sort or the other. If you are handy, pull the head off the side not pumping and see is a valve is broken or something stuck in it.
Also see if you can get a break down with part numbers and if parts are still available. Likely that pump is pricey if it is quality and should be repairable by you or a shop.
G
G-Ram
NWO
No brand stamping that I can see, only "Made in USA" on one cover, TX002 on another, and this small plaque:
md21722
Mt Juliet, TN
It is in fact a Campbell Housefeld CI100000P pump. Rated for up to 10HP. Pull the heads and check the valves and go from there. May be an easy fix.
G
G-Ram
NWO
Will pull the heads tomorrow and report back. Not sure what exactly I'm looking for, unless of course something jumps right out at me. Auto mechanic by trade so I'm sure I can hack my way through it. I've never messed with compressors before though. Will be interesting to see the inner workings and maybe learn a thing or 2 [emoji106] thanks for all the replies and help
sld961
I'll be the first to say it. You ****. That's a heck of a deal for a case of beer, even if the pump needs rebuilt.
redmondjp
Redmond, WA
Email campbell hausfeld the pics. I'd put money on that being one of their industrial pumps.
Yup. I came here to say CH as well. That crankcase pressure vent is a dead giveaway.
And was it worth it, HECK YEAH! Just for the 7.5HP single-phase motor alone. Look up one of those babies and see what it costs new.
Oh, by any chance did your buddy give you the motor starter as well? If not, the followup question is: does he know where it is and can he still get it?
G
G-Ram
NWO
Would that be this badboy?
CNGsaves
KS and OK
Hell yeah you SCORED big time on that compressor . . .
. . . . . .EVERYthing is good stuff . . .
. . . . . . . Baldor 7.5 HP single phase motor
. . . . . . . . .excellent starter controls
. . . . . . . . . . .pump is definitely industrial
. . . . . . . . . . . . tank appears in good condition (use endoscope to examine)
Darn tooting . . . . YOU **** !!! :thumbup: . . :beer:
Give that puppy all the attention it needs for full restoration . . .
. . . . AND . . . . you'll have LIFETIME of air !!
Drain oil and take off inspection plate to check for any metal shavings in crankcase or any rod, crank, or cylinder damage.
G
G-Ram
NWO
Wow, my first ever "you ****" on the GJ! Thanks for all the help guys, I figured it was worth some money, but had several people telling me not to waste my time. Thanks for the reassurance, I will update this thread as I complete the tear down.
