Royce: i had my doubts when you showed us the parts, but i think i like this stand vise combo maybe even more than your fire hydrant vise stands.
do you use BLO to put the shine on your stuff or do tell?
WELL DONE!!
isn't the Prentiss #20 swivel jaw vise about 100 years old and a 5 inch wide jaw that weighs about 75 pounds? nice vise too.
Neat idea. FYI that shape cross sectional is called a deltoid or tricuspoid. You seldom see them in structural pieces are they offer little benefit while being difficult to manufacture.
Drives,Royce: if you apply the mixture hot does it cure quicker? also are how are you heating it up? stove in your house or do you have a shop oven or microwave? or maybe you just put in a can and use your torch.
i love the naked steel look and looking for an easier way to put my BLO on my STUFF than just with a rag.
I have a nice Prentiss #20 somewhere, but not sure exactly where and thought it was 5 inch wide jaw. in any case a great vise and looks even better on your stand.
whatever those words ZK used to describe the shape of steel you made are new to me too.
Drives,
Yes, heat the work up till when you spit on it it it flashes to steam, it will cure quicker.
I heat the mixture in a coffee can on a gas cooker, just have a lid ready,because it will catch on fire.
I don't think there is anything easier than a oil finish applied with a rag.
Royce
What proportions of Linseed oil, beeswax and naphtha do you use? It certainly looks nice when it's finished!
G-Man,
I don't measure, maybe 1 part wax, 3 parts oil, 1 part thinner.
I don't think the proportions or oil type matters to much, but the heat and beeswax do seem to help with keeping corrosion at bay.
Royce
Royce: thanks for the 411 on the Beeswax mix and application. just curious once you have the original coating on how often do you need to re apply and do you just wipe on the following coats without heating them up?
i really can't believe how good that stand looks and maybe the cool old Prentiss #20 swivel jaw vise helps.
Everybody knows what a I-beam is and why, so I guess you could call this a tri-beam.
I cut these tapered rips out of a piece of 16"x .375 wall pipe.
The base is 10" across the sides and the top is 6".
Royce
