ffast65
just put mine back together monday night. Works like a charm once full with hydraulic oil.
Mine is branded Fleet however is the exact jack.
This is a Great thread! I got a WA-72 today. My date code is 2DE121. When was it made?
There is a PVC sleeve on my handle and when I take it off, the button on the handle pops up and the handle falls down. Whats the fix? Thanks!
How do you get to the release o-rings to replace them. All I can see on mine is a brass washer thing in the hole and I cant remove it.
oh sorry the release needle valve o rings
I did the air bleed procedure and saddle still pumps up on the downstroke and falls back down on the upstroke. Maybe something with the check balls? I put in the small one then the ball weight thing and then the big ball and put on the cap with a new gasket (steel ring).
Ok... It is amazing how a couple days away from a project along with some good feedback can do to help solve a problem. I had confirmed earlier the pump plunger moved freely in the cylinder without any binding, so it had to be something with the cup and or packings.
I removed the pump plunger and wanted to ensure there was no cup bulging issues from over tightening. So I used a punch to crush a couple stud mounting bolt threads so I could tighten the nut without over torquing the cup.
Then I only hand tightened the packing nut. I saw an immediate difference with the pump pedal as it was returning normally (still not fully, but a new spring and lube on the pump pedal mechanics will help that issue). I also cranked down on the tank again and I am fairly sure that leak was addressed as well. I still need to test with a vehicle, but I am very satisfied with the results. Now I can start the fun stripping process for paint. Think I may look for a used sand blaster.
Thanks again HiBall!!!
Here's a picture of the pump plunger cup:
And the replacement return spring from McMaster. They came in package of 5 and matched all the specs (wire size and OD), but I cut it to length. The old one is on top.
