So I'm to the point of planning electric in my 40x48 pole barn.
I'm planning on 2 outlets at every post, each on a different circuit, Lights, and a few outside lights and outlets. The panel is on the back wall in the corner.
I have 3 main questions.
#1
For the 2 outlets at each post, can I use 12-2-2 and run only one wire, but still be able to have 2 different circuits?
#2
For the front wall outlets, the run will be 48 feet up the Side wall, then have outlets start and run for 40' across the front wall. Is 12-2 gonna be sufficient for this as well?
#3
For the cieling lights, everything is open now, but I do plan on insulation, vapor barrier, and white metal. For you that have been there, what's the easiest way to go about wiring the lights? Put boxes and outlets or just leave the wire hang out of the cieling? I think I'm set on t5 Ho's, but haven't come up with a lay out, done any of that math (that'll be a whole other thread). I do want 3 switches so I can control either side and the middle.
#1
#2
#3
