Time machine: what would you do different?
dmaxedout
Starting my 30x50 steel building, pulling my hair out trying to plan ahead and make everything perfect. So the question is, if you could go back in time when building/setting up your shop what would you do different?
barks
Learn at a lot earlier age that few, if any, things are "perfect".
rburke65
Canfield, Ohio
Just do a 40' X 60' x14' and you won't hate yourself. BUT.......make damn sure that your foot print of your build is " high and dry". There are more folks on here that do not or have not, planed from the bottom up. It all start with site preperation..... Good luck.
Edv530i
Central New Jersey
Which side of the building are your overhead doors going on? I agree that you should go 40 deep but it really depends on how you intend to use the space. Mine is 40 deep and 80 wide and my bay doors are along the 80 side. I went with 3 - 10 wide by 12 high doors. I should have gone at least 12-14 ft wide so I could bring vehicles in on more of an angle.
Crazyjake8493
Upstate NY
Garage related: finished walls, then surface-mounted all electrical
House related: saved longer and bought a nicer/newer house
Life related: gone to college after high school
sberry
Brethren, Michigan
If there is snow and ice it makes advantages of a wider building and going in from the gable end so much better and there wont need to be loaded headers needed. I see so many buildings look like they were designed on a nice summer day over a discussion with a second rate pole barn builder who must agree that all customer ideas are good to make the sale and not offer up any experience/advice which often may be as or more important than every nail straight. I see a lot of "extra" side roll up doors in garages and small buildings that must have seemed like a good idea at the time to someone, never used with grass going in front of them.
sberry
Brethren, Michigan
Get the doors right, in a bit bigger buildings this may mean less doors but a bit bigger. In mine could live thru 1 of 4 and do in the winter. I use the others but getting the entrance and drive in correct makes up for some although in smaller buildings there ay not be enough space for driveways.
30x40 is common but really too narrow for 2 doors let alone 3 and 2 cars wide on one leaves no space along the walls, huge mistake going too small. Seen it, wasted huge amount of storage along walls and always felt crowded working.
12 ft wide doors are so much better, have a bud with 10 in auto shop and you have to be fussy and even creates a foot path bottleneck when they are open.
bowhuntr311
North Central Minnesota
I have a 40x40x10 with 3 10ft wide doors. I would do 2-14 foot wide doors. I would also have put a water line to the front of the shop so I could wash trucks in the driveway and not have to string a hose from the house. Also would have laid a conduit from the house basement utility room to my shop, that way I could run a cable across for security cams.
ekraft84
Less slope in the garage floor. Made leveling things (cabinets, tables, lifts, etc.) more of a hassle.
Also, run electrical in the floor and allow for any floating benches/tables to be powered, that aren't near a wall.
Rod N
Keswick, Ontario
I'm pretty happy with the way my garage has turned out.
As far as life, come to realize when I was young that all woman are nuts and reduce the amount of x wives. :dunno:
Automobilist
Snohomish County, WA
In the process of planning for our shop. Will be around 50' X 40' or so. Or would 36X56 be better? Use will be; working on our vintage sports cars. Being new to the rainy northwest, what's the strategy regarding doors on gable end v. side? Yes, I'm ignorant on this but want to get it right... :thumbup:
Thanks!
Ed
homebuilt burner
central Wisconsin
Get a very large pad of graph paper to draw out different sizes and door configurations. Then cut out scale models of your car, boat, other toys and lay out how YOU are going to use it. My use is different than yours will be.
My only regret was size, I built what would fit and we could afford. But I'm still happy.
GTO
NJ,FL
Install a minimum of a 100 amp box instead of my 60 amp.
Going back even further I would have saved more money,could have been retired by now.
Edv530i
Central New Jersey
I cannot agree more. Many of the other things mentioned in this thread are fixable but once built dimensions and doors are not changeable. I originally wanted to enter from the gable end and positioned the building so that I could but my wife's only stipulation when I showed her the design was that I move the building over toward the trees and property line thus not leaving enough room to enter on that side...leaving me with the 3 - 10x12 doors on the 80 ft side...which should have been wider. Repositioning wasn't an option as 40x80 is pretty big for a 2 acre lot (township had 900 sq ft limit so my variance cost like 6k...welcome to New Jersey!)
I have another piece of property (3.5 acres) that I consider building another one on and I would like to build a 60x120 with 2 large gable end doors...but 2 things hold me up...don't know if the township will let me build one that big and I don't know if I want to pull out a mortgage on that property to do it.
D
dmaxedout
Stuck with the 30x50 because it's the most that will fit in the space I have to build.
widerberg
Down South
Mine's a bit of a hodgepodge and I'm having the damndest time cleaning/organizing enough to make headway on finishing the interior. It's about 1/3 painted, and has been that way since Father's Day 2014. Life continues to happen. If I had it to do all over, I would've painted it, sorted out the flooring, and did all of the stuff you do with the "bones" before ever moving my stuff into it. Would've been a lot easier.
Also, I don't know how many cabinets and large tools I've scored over the years because they were a "deal", only to end up tossing them out or Craigslisting them because there just isn't space or a need now. So . . . I should've assessed my needs and planned better from the beginning, rather than let the garage grow organically into something that isn't at all what I'd hoped.
Having said that, I'm chipping away at making it right. But, I could've made life a lot easier for myself. Live and learn.
Crazyjake8493
Upstate NY
I agree with everything here^^^
I also moved everything in the garage right away and then all the electrical and wall/ceiling finishing took 3 times as long as they should have, since everything in the way needed to be moved multiple times.
I had many similar experiences with "deals" and CL and clearance stuff at the big stores that I ended up not needing and took a loss on them. I think a lot of it had to do with not having a lot of money after moving in, so I tried to score any deal I could, and ended up with too much clutter. Lost a bit of money of some stuff.
Luckily, I've managed to stop doing that. Now I only pick up an item on CL if it's something I've been needing or searching for, or if I can turn a quick profit on it. I stopped going to yard sales too. I look around the garage occasionally, and anything that doesn't get used often or that I don't need anymore, gets sold or tossed. Cleaned up a lot of space in there. Now, if I could only get my dad to do the same thing.
Alchymist
Central PA
Socked away a lot more money in pension plans all through my working years. Would be on easy street if I had.
ambenz
NW Chicago Suburbs
I did a lot of things right, surprisingly...and am pretty happy with it all.
Things I wanted to do, the village tied my hands, so I live with what I could place.
I suggest you know how big you can build, and build it based on what you can get away with. Go into debt and wish for as many things as you want....if you are young enough, you will afford it in the long run and increase your property value...and taxable property value will increase too, unfortunately. It is amazing how time causes the soil line to increase around buildings. Between sink-age and particulate matter in the air, 50 years in the future, your building can actually be lower than your ground....build it high and dry! Make sure the building can support a future lift.
In hindsight, collecting gutter rainwater for irrigation and storing it underground in a cistern would be very handy since our water rates for Lake Michigan water continue to skyrocket. Insulate with styrofoam and never worry about the insulation breaking down from moisture, rodents, or gravity. Plan for a security system, both passive and active.
Bolster deadbolts, install window bars, cameras, etc....as you see fit.
Good luck!
