mason_tay
You know the type, insulated, ect. What do you carry? Good brands? What won't break the bank but still quality?
If you will be using them more regularly, between the Wiha and Wera I think the Wiha are a bit better. I have both brands of screwdrivers and my Wiha tips are tougher, especially the Phillips tips. I also have regular Klein screwdrivers that I used to use daily when I was a wireman. They are good too, but mine are older and there are lots of reports of modern Klein tips not being as good as they used to be so I can't comment on them now. I haven't used every brand, but I have used a lot of the main good quality brands. In my opinion Wiha (German made only, I don't have any experience with the foreign COO stuff they make) makes about the toughest wearing screwdrivers you can buy. Their precision slotted drivers are all I use now, they are just amazing for small tech type work.
In case it matters, Wiha does also make slimline insulated drivers that have the insulation flush with the screwdriver shaft so the drivers can still reach recessed screws without the shaft insulation sometimes hitting the edge of the recessed hole. Sets like Wiha 32196. They are more expensive though. I got around that issue by getting the cheaper insulated set and then cutting off the first inch or so of the screwdiver shaft insulation so they remain mostly insulated but they can still reach all tightly recessed screws.
I have Wiha insulated. I like them, but sometimes its hard to get a lot of torque on them.
I really like my FELO insulated bit holder:
I have non-insl Klein, but mostly i use my ratcheting Snap-on with a phillips.
I also have a Felo Ergonic No.1 square for combo screws.
Bit-holders are kind of a no-no with high voltage. If a bit falls out into a panel it could vaporize it
I have this as well. Plus a 4PC set of the same handle drivers. 2 Phillips and 2 slotted. I really like them.
I, too, had this concern. I am impressed with the magnet retention. Its very strong.
Now you just need that Ravens NFL ratcheting Snap-on screwdriver. ;-)
Klein might be OK for attaching plastic cover plates, but forget Klein if you ever have to deal with tight screws. One camout and the tip will be ruined.
Somewhere along the line Klein lost or cheapened their process for hardening screwdriver tips.
I tossed the last of my newer Kleins. Almost any brand is better then new Kleins. (old Kleins were good though)
Mid-2013 Klein started manufacturing a new stronger screwdriver steel for their phillips and square drivers.
Again I come back to: don't use bit holders on electrical work...
My Knipex linesman is a work of art. My insulated Wera screwdrivers with laser tips are way better than any Klein driver I have. It would be one thing if Klein was a budget brand or even moderately priced, but pretty much everything they sell has premium pricing. I've bought my share of Klein, but when it breaks it'll most likely be replaced with something else.
...Any German brand will do, they have a standard, VDE, and all the screwdrivers that bear that seal are tested individually. Wouldn't touch milwaukee or any other chi com **** with a 10' pole.
