new to this board... saw this (it looks great) and had a few questions.. I am looking to create a 2 story garage (barn like looking structure) 36 X 44. wood shop on 2nd story...
Few questions (if you dont mind...):
It looks as though you do the following...
footings... then block.. then waterproofing coating called Tremproof 250 GC.
Then rigid foam...
1) Does foam come in different thickness and what do you use based on what?
2) Does the waterproof coating and this foam also get done to inside block wall?
back fill dirt... pour stone and level inside...
3)what is used? how many inches?
then vapor barrier Stego, 15mil. thick (Looks to be placed up side wall from the floor...
4) Does the vapor barrier go vertical the floor thickness and is cement floor to be
6.75" in your case (what should floor thickness be?)?
Is the floor thickness 6.75 minus floor foam thickness?
Then tape seams of vapor barrier...
Install Expanded polystyrene (EPS) - Saw this website for info
http://www.epsmolders.org/3-sheathing.html
5) Inside - What thickness EPS on floor did you use? how fastened? Tape joints?
The radiant tubing will be 6 loops @ 300' each of 1/2" PEX
6) How to determine number of loops and lengths? Distance tubing sits apart?
Any special things to do pattern wise?
wire supports that come in different heights which act to suspend the
rebar (and/or wwr) in the middle of the slab.
7) how to determine distance apart and height?
Then cement....
8)thickness?
quote -
Not a very good shot, but I ran the (6.75") eps across the opening and backed it up with a 2x6 on the outside.
9) 2x6 is just so cement dont blow it out during pour?
quote -
I added a 1.25" thick piece of foam to the top of this and had them finish the floor to this height. When the floor has cured, I'll remove that piece and the overhead doors will sit down into the pocket.
10) Does this create an "L" shape (side view) where the doors sits against?
Or does this create a "U" (square corners - side view that the door sits down into?
The "U" doesnt seem right, but I figured I ask...
Generic questions:
11) What is the source - hot water heater? size? Who/what pump is used?
12) what is an estimate of cost for this entire system?
13) operational costs?
14) any other questions I should ask?
15) your overall experience (good /bad) with this set up?
I don't mind you not answering if you dont mind my asking...
