Looking for ideas for inside walls....
FunBags
New Brunswick, Canada
I have been looking at doing the metal siding/roofing whatever ends up cheaper for my interior walls. I'm sure someone will post up, I've seen it done a few times on here.
slow
near Orlando
FRP or fiberglass reinforced paneling. Used in commercial bathrooms and kitchens. It is available in colors and the light gray would look good. Available in 4 by 8 sheets.
D45
NW INDIANA
pamike
Central PA
3/4" plywood 8 ft high. Tin from 8 ft to 16 ft..Painted the Sherwin Williams precat epoxy primer on the plywood. Good durable paint..
ozyborn
If you are looking to kids proof it. I doubt even battleship plate will do.
motofool33
Currently North of Houston
I have metal siding roofing in my garage, hate it hard to mount anythung, you loose 2 inches of space due to ribs sticking out. Will never do it again.
Sent from my SAMSUNG-SM-G900A using Tapatalk
ShumanSS6.0
Minnesota
Ain't that the truth!
I went with drywall on the bottom 4 feet and then slatwall up to the ceiling. Gives me the versatility to swap things around and adjust storage if needed.
