Hammer time!
Fordriver6
Afton, VA
arrived today. Artamount 5" jewelers hammer and 7" brass jewelers hammer.
I am not seeing any markings on the brass hammer:
Artamount jewelers hammer 01 by four.cycle, on Flickr
Artamount jewelers hammer 02 by four.cycle, on Flickr
brass jewelers hammer by four.cycle, on Flickr
I have one similar to your jeweler's hammer. In addition to the GAM lettering on the head, it has "Mfg. By GAM Mfg. Co. Lancaster, PA" on the handle (have to roll it around to read it all so hard to get a picture).
Has 4 different size flat screwdrivers that fit into the handle., which in turn screws into the shaft coming off the hammer head. I've only put a very small amount of research into it, so any insights would be appreciated.
Sent from my XT1080 using Tapatalk
Fordriver6
Afton, VA
In addition to the novelty hammer I just asked about, figured I would show the hammers I actually use.
These are the ones to the right of the rubber mallets.
The two bigger ones are Plumbs and the small tack hammer is a SA RE?
Interesting that it has a slot hole and a split in the face, which is magnetic.
jakemac
New England
Just picked up this 2lb hand sledge this morning.
jakemac
New England
There is no brand name, but from the logo I believe it's an Atha (pre-Stanley). So, the head could be over a hundred years old, and still in service.
SilverDeck
Yep. Definitely an Atha. They continued to make hammers with the Atha logo after the acquisition by Stanley, I believe. I was thinking Atha-marked striking tools might have even been produced into the 1930s. Alloy Artifacts might have some more specific information on this topic.
Cope
Houston, TX
My hammers. No nail, sledge or other non-metal working hammers here.
drsung
Louisiana
Wow! What a hammer resource this thread is.
I found this guy on the side of the road the other day. It had a way too small handle siliconed in. I removed the handle and soaked the head in some simple green overnight. I plan on getting another handle and giving it a new lease on life.
At just the right angle I can make out a "AN" engraving so I am assuming it's a craftsman.
I don't have a scale to weigh it but I am assuming it's about 12 oz.
Anybody have any additional insight?
d.mcfarland
Western PA
^^ =Craftsman=
[/URL]
Have you posted your steps in restoring a hammer head before?
SilverDeck
Definitely a Craftsman hammer that was produced by Vaughan Manufacturing
bulletpruf
San Antonio
jakemac
New England
What ????
OK guys, I need some help figuring this one out.
There are no markings, I think it may be homemade.
it looks like a curved double cross pein, but both faces are ground sharp.
:headscrat :willy_nil
Feel free to chime in, 'cuz I got nuttin'.
O
I agree, custom made by or for a metal worker for specialty work; likely automotive and I'll go further and guess in aluminum, as I don't think those sharp edges woud remain sharp long on steel.
If not aluminum; possibly light work like early lanterns and lamps? Are you near any Amish?
jakemac
New England
Not sure, I'm not familiar with all my neighbor's last names. :lol_hitti
This guy had a few interests. One room was set up for woodworking, the other two had lots of electronics he was tinkering with. Given how well the '49 Monarch was kept, I suspect the garage was set up for mechanics work. Won't know until we get in there in a few weeks.
paulm12
NW Chicago 'burbs
picked this up hoping to determine the maker. No luck
Ole Slewfoot
Freedom, CA
Had this old hammer awhile, finally figured out its an Atha with a double stamp. 3lb, but seems oddly more long and pointy than most. Im thinking thay makes it not really a drilling hammer? Seems big for a tack hammer. There seem to be a variety of posdible markings, but I didnt find any resources arranging them chronologically.
wafrederick
Holton,Mi
I have a Pro Grade hammer purchased from Tractor Supply,about 10 years old and still use it to this day.I believe it is a 32 ounce and never broken it yet.One tough hammer with the black and yellow fiberglass handle with no complaints with it.
T45
I have a question for the thread-- what is with the prevalance of shelac/clear type coatings on modern hammers? do you dress the face and take this off, or is it harmless? the striking face seems to pit/chip the shelac which seems much softer than the proper metal face. Before taking up this issue wanted to ask what the best practice was in dealing with it.
Cheers. :beer:
LG63
I have a question for the thread-- what is with the prevalance of shelac/clear type coatings on modern hammpers? do you dress the face and take this off, or is it harmless? the striking face seems to pit/chip the shelac which seems much softer than the proper metal face. Before taking up this issue wanted to ask what the best practice was in dealing with it.
Cheers. :beer:
And I thought I was the only one that noticed this. I remove the coating with a knot type wire brush on my 4.5" grinder.
pstemari
Seattle
Why do you need to deal with it? I have a bunch of Estwing ball peins with the shellac. I just ignore it and figure that normal usage will get rid of it over time.
Sent from my Pixel XL using Tapatalk
O
Pretty much what sptemari said. Just leave it, unless you are just that OCD, or have concerns that the clear finish chips may contaminate the work area, then wire wheel as LG suggested...
BrettJ74
Vancouver Washington
Thought I might add a few pictures of my ever increasing hammer collection. I had bought this Plumb Boy Scout hatchet then after much research on Plumb I figured I had better start picking these guys up when I see them. I particularly like the fiberglass handled Plumb claw. The glass was all dried out and splintering so I sanded it down and applied some West System epoxy to re seal it, now I m looking for a fiberglass Plumb ball peen to match. But I try not to discriminate and if I see a quality old hammer I usually pick it up.
The others include Vaughn, Mac, Williams, D. Maydole, True Temper, and Estwing. If nothing else while out treasure hunting I can usually find a good hammer or two[emoji106] a360998ba6a69d915445107cc09f3e3b.jpged3fd6e944d2e48189acdbc9d65b0650.jpg74c6be09776aef06c38d25c4a63be5e1.jpg
Sent from my SM-G955U using Tapatalk
davethorik
Norka, Ohio
I will say this...the shellac will be gone in under one year if you use the hammer frequently. Also, the hammer will still rust with the coating on it. It does keep the flash rusting at bay fairly well, but is not the be all end all of rust preventatives. I love Estwings. Just used the drilling hammer today.
freudianfloyd
Nowhere
Here are a couple hammers I bought recently at some yard sales.
First one is a 3lb USA Stanley mini sledge that was covered in rust and missing a handle.
[/URL][/IMG]
Walked across the street to another yard sale and bought a handle. Brought it home and after some wire brushing and handle transplant I have a nice hammer to keep with my anvil.
[/URL][/IMG]
The next week I went to a yard sale and found the Williams body hammer seen here. (Sorry for the bad picture).
[/URL][/IMG]
The picture is a little misleading, the head was rust covered but that picture was after some scotchbrite work. Also, the head looked like it was used for hammering nails, it was dinged and dented and rusty. After a few hours of scrubbing and polishing I got it back to a mirror polish, and then added some (blue anodized coating) paint so that the shiny would show through. Also sanded down and refinished the handle while I was at it. I'm pretty happy with the way it turned out. It's currently the jewel in my toolbox.
[/URL][/IMG]
[/URL][/IMG]
EOC_Jason
Bentonville, AR
I have an Atha similar size & shape. I'll have to take better pics but this is one I had on my phone already. Also I'll have to see if there was a weight stamp on the other side. The handle is really short, I always assumed it was intended for general blacksmithing...
I recently added a rack to the end of my workbench for most of my hammers. So much more convenient than having them hanging on pegboard stacked several deep.
Got a box full of goodies from a recent estate sale (Last day, everything 70% off). Still have to go through and clean them up. My favorite is a Heller, I'll have to take a picture of it, I really like the handle.
Lastly is a picture of a ball peen hammer that I can't quite figure out the maker. Diamond shape on the outside, an anvil in the center. Bottom text reads Cast Steel... Top text I'm not sure about... I can get a closer pic if it will help, but I figure someone knows with the anvil logo in there...
freudianfloyd
Nowhere
