Repainting Wilton Machinist Vise - Any Tips?
rhastings80
Hi Everyone,
I picked up this Wilton Machinist Vise. It is from 1980. I have spent quite a bit of time using my angle grinder with a wire disc to remove the old paint and rust. Then I cleaned with Dawn and water. After that I used Duplicolor Grease and Wax Remover. After that I rinsed with water and used some Rust Bullet Metal Blast and rinsed with water, dried and then let sit in the sun.
I was thinking I would paint with the Duplicolor engine primer and then the Duplicolor 500F engine paint. Then thought after 3 days I would cook it on my outside grill at 200F. My other thought was appliance paint from Home Depot but all they have is white. I was planning on painting a glossy gray.
Does anybody know of some better paint I could use? And if so where would I get it? This will be my first time trying to paint something where I took the time to clean it well. I don't have a big compressor or large setup so it would have to be something either I spray on via a spray paint can or something I can brush on. After spening what feels like 5 or 6 hours cleaning up this vise I'm hoping the paint doesn't peel or scratch off easy.
Thanks,
Rob
:bowdown:
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/wWtRaXv4pggHWbUB_5v7Sw?feat=embedwebsite"><img src="http://lh6.ggpht.com/_gyA2MJjiLlg/Sr_Kh15zpfI/AAAAAAAAAIM/h4bWvdHjfQg/s144/IMG_4200.jpg" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/kcTwO6U6WOHQSG9deqmmTA?feat=embedwebsite"><img src="http://lh3.ggpht.com/_gyA2MJjiLlg/Sr_KicimGJI/AAAAAAAAAIQ/ceIsoJ18Iow/s144/IMG_4201.jpg" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/cpVOMa3ufyjEF5uzhyNk-A?feat=embedwebsite"><img src="http://lh3.ggpht.com/_gyA2MJjiLlg/Sr_KiqGJvNI/AAAAAAAAAIU/0otIAdQ2wSU/s144/IMG_4202.jpg" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/tEgSL24awv89ywgA-MOf3g?feat=embedwebsite"><img src="http://lh4.ggpht.com/_gyA2MJjiLlg/Sr_KjA7klmI/AAAAAAAAAIY/AYzxX2pq0Js/s144/IMG_4203.jpg" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/l4bDGUlvSj-FaFKugEIS6g?feat=embedwebsite"><img src="http://lh3.ggpht.com/_gyA2MJjiLlg/Sr_KjcQ6kxI/AAAAAAAAAIc/6VoQshbPzeU/s144/IMG_4204.jpg" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/lNvfRSmT_KhIUbyF07S4tg?feat=embedwebsite"><img src="http://lh5.ggpht.com/_gyA2MJjiLlg/Sr_LFYDs8RI/AAAAAAAAAIk/aMilqKtLiwc/s144/IMG_4206.jpg" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/p2RvnVpSTf3cWrRA93Dj-A?feat=embedwebsite"><img src="http://lh5.ggpht.com/_gyA2MJjiLlg/Sr_LF4c2JeI/AAAAAAAAAIo/chHftAIHL8Q/s144/IMG_4205.jpg" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
back2class
Don't bother with any spray paints as they will be delicate. A brushed rusteoium job is best. It is soft enough where it wont chip and is still durable. It is a vise and will get banged up one would hope. This is one case where the easiest product is also the best one to use.
mjozefow
Lafayette, IN
Nice vise!
I sprayed rustoleum onto warm parts for mine. Nothing you put on it is going to resist grinding or otherwise. But rustoleum is easy to touch-up.
evintho
Santa Rosa, CA.
I just restored a Wilton and this is what I used. I'm very happy with the results!
From this....................................
To this.......................................
Here's the entire thread...................
Wilton vise restoration
evintho
Santa Rosa, CA.
Yep you brush it on. I used a cheap 2" brush bought at the $1 store. I brushed on 1 coat of primer and 2 coats of color. Put it on thick and let it dry 24 hours between each coat, including primer. After final coat it takes 3-4 days to really harden but once it does, it's very durable!
airdale
Oregon
One tough spray paint I've used (on wheels) is called Steel Wheels, it's a silver-gray color. At McMaster-Carr they sell a polyurethane spray paint with stainless steel in it. On the same page they sell quarts (solvent based). 2-part epoxies are tough, but a lot will be wasted unless you can measure out ratios carefully. Also on the same page they have one listed as fast drying water bourne, that works surprisingly well (made by Burke Coatings) again with stainless steel. Another idea for a working vise is galvanizing spray. They tend to be softer than most paint, but protect from rust and are easy to touch-up. The ones called cold galvanizing are dull gray. Bright galvanizing are shiny silver metallic but some are more prone to particles rubbing off. Frankly, a lot of them I have not been happy with regarding rub resistance. Currently trying out Crown's Galva Bright and it seems to hold the most promise. It's color is like a satin chrome.
Vinko
Los Angeles
I noticed the little can (next to the rusty metal primer) is called lettering enamel. Presumably, for lettering :). But is this name just a gimmick, or is there something about this enamel that you like for raised lettering?
scottg1952
Happy Camp
Any industrial type alkyd enamel is about the best you can hope for. If its inside and protected it will last a good long time.
I use never seize on the moving parts, where the sun don't shine.
yours Scott
evintho
Santa Rosa, CA.
No gimmick. One-Shot is what the pros use for pinstriping hot rods. I used it to highlight the Turbo Coupe letters on my TC. It's top quality stuff, surprisingly inexpensive and is perfect for the raised lettering on the vise!
R
rhastings80
Well I finally got around to painting this. Had to wait for a warm day. Here is what it looks like after the first coat. I will probably due 3 coats. I will also post pictures when I have it all assembled.
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/pa98_QbgDogTUUaZ9fBD3w?feat=embedwebsite"><img src="http://lh6.ggpht.com/_gyA2MJjiLlg/Ss0AFRYPGPI/AAAAAAAAAJE/F1_297wWmU0/s144/IMG_4228.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/MEdxJhfkpr2oiGHd_I-41w?feat=embedwebsite"><img src="http://lh4.ggpht.com/_gyA2MJjiLlg/Ss0AFhFkQUI/AAAAAAAAAJI/6rBaQ_q8z6g/s144/IMG_4229.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/DofY3teCuVBRP1Wn85ZbWg?feat=embedwebsite"><img src="http://lh4.ggpht.com/_gyA2MJjiLlg/Ss0AGPiyXWI/AAAAAAAAAJM/qHPZUR8tIFI/s288/IMG_4230.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/H5dPz5mZVfUeOgyeWEK8fw?feat=embedwebsite"><img src="http://lh6.ggpht.com/_gyA2MJjiLlg/Ss0AGbbzA3I/AAAAAAAAAJQ/3AngXd5wnOE/s288/IMG_4231.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/mike.4324/Vise?feat=embedwebsite">Vise</a></td></tr></table>
evintho
Santa Rosa, CA.
Nice job! Looks good! When you reassemble it fill a large cup with 90 weight gear oil and dunk the moveable jaw slide in it. Also, grease the spindle worm gear threads liberally with general purpose grease and you'll be good to go!
scooby074
Nova Scotia
A little late, but for refinishing vises i like Rustoleum Hammered finish.
I sandblast first then paint with a brush. A tough durable finish (i use my tools pretty hard). The Hammertone (hammered) finishes are much tougher than regular enamel in my experience.
