Garage in a disused factory in Norway
akiwinut
Bonnie Doon, Victoria, Australia
So I started painting the wall before continuing with the mezzanine.
Immediately when I started to paint the wall I was regretting. Not because of the color, but the fact that the structure of the wall is so rough that it takes forever to paint it. So I will be busy for a while....
The 20 litres (5 gallons) of paint I bought will not get me far.
Can you hire an airless sprayer to paint the walls, will be much quicker than brush or roller?
s123
Norway
I think you are making the right choice. The graffiti was unique, but having white walls will really add some brightness and freshness to the space. Keep up the great work!
Thanks, I think it is a good decision - I will hang in there!
Paint should be one specifically for concrete block like DryLock (US Product)http://www.drylok.com/. Regular paint will get sucked up and look blotchy
Yes, that would be the best choice - but I checked the prices for paint for concrete blocks, wich was out of range in my restricted budget for this project. Even keeping in mind that I will use much less paint.
Because of the grafitti the walls are "primed", so it is more of a matter of finding a better way of transfering the paint :)
I also think You would be really dizzy in your head after a while.
Luckily the paint have fewer fumes than before, but dizziness can still be an issue. Some might say I'm dizzy anyway :)
Very cool space! Nice to see a cool garage in Norway, which I will be in next week
:beer:
Thank you! Would not mind having the flooring you sell - and very much welcome to Norway!
Nice work on this it looks very good so far!
Thanks a lot!
Subscribed, we are taking a Baltic sea cruise next year that stops in Norway. Looks beautiful there!
If your cruise ship will go to Oslo, you will pass my hometown by the Oslofjord!
nice work on that mezzanine
Thanks! Still a way to go. Also like the way you painted your cabinets!
Yes, I've been thinking to use some kind of spray gun, but been looking to buy something I also can use for later.
s123
Norway
Thanks a lot for all your comments and tips. Very much appreciated!
So when I arrived the garage my friendly 'garagemates' have been busy, painting the walls in the corridor and also painted my garagedoor! This give me a boost to strive furter! Thank you fellas!
I have been at the notorious shop named Biltema, which is a scanidavian company selling tools of very varying quality. I have picked up a resonabely priced spray gun for paint and hope it will last the warranty period :thumbup:
It was quite simple to use and well suited for my cheap paint. I got very good instructions for thinning out the paint to it was sprayable. So I quickly masked the areas. I was quite surprised of how much noise the spray gun was making. My fella garage buddies thought I was vacuum cleaning vith a very noisy vacuum cleaner. Yes, of course I was using my hearing protection.
As you can see, the paint is much thinner than the part which I have rolled out with a roller. The work went effortlessly! In just a few hours what would taken days, so I'm a happy bunny :lol:!
Bagsf18
woodstock JAWja
If a cheap tool works, it does not make it a bad tool!!
This is a very interesting concept. And it looks like you are coming along well. Thanks for sharing!
And keep the updates coming. And remember, slow updates are still updates, which means you are moving forward!!
s123
Norway
That is true! The spray gun is noisy, but does the job much better than rolling the paint on the rough surface. Quite fun to work with actually!
I will try my best to keep the updates coming, but most often there is not that much progress to report about!
Brunow
Belgium
Good luck with the space, any pic's of the outside?
Do you have a seperate fuse box?
s123
Norway
Thank you. Actually I have never taken any photos outside. From Google Earth I took this screenshot of the property. My small garage is almost in the middle of the building.
I do not have a separate fusebox. Since it is a former factory, previously with rather power hungry equipment, it is not any capacity issues with the power supply. There are large fuse boxes in each "module" of the building. Electricity and lighting will be put up by an electrician when I'm finished with my carpenter work. The electricity usage is included in the rent.
s123
Norway
So I have continued with the painting. The plaster surface and the green metal door was easier to roll than to use the spray gun, but the real timesaver was to avoid rolling the concrete blocks. So this is how it looks after two layers of paint.
The other green door, outside the mezzanine I will keep the grafitti.
s123
Norway
So the work contiunes by placing the joist hangers, try to find the right position so it is easy to mount the structural timber afterwards.
s123
Norway
So there is a slight progress. The bearing for the mezzanine floor is about to be finished. Next now is to put up the floor.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Everything is looking great so far. I think you'll like the white better than the graffiti, but the graffiti was damn cool. I hope you took some good pictures of it, so you can get them enlarged to maybe a poster sized print, frame it, and then hang it/them on the walls for decoration and a reminder as to what it looked like.
As far as the mezzanine, it's to bad that you couldn't have had that space to just kick back, watch a little TV when you were done working on cars, and relax with a few cold ones and friends. But storage is also needed. And possibly on down the road, you may want to add a mezzanine over the other half to do just that. You never know. But all in all, you have a nice looking garage.
arsco
Ma
probably a good idea to add some blocking on the joist
s123
Norway
Thanks a lot Kevin54. The white is more a necessity for the light. I really liked the grafitti, and have kept the green door on the outside of the mezzanine with its grafitti. I also have pictures of all the walls before painting them.
Up on the Mezzanine will make some shelves for my storage needs, but I think it will be room enough to have a area with a table and a couple of chairs. It cannot be to comfy, then I will not get anything done on my car :beer2:
Thanks for your comment Arsco! I'm not quite sure if I understand what you mean, nice if you can clarify. Do you mean to mount blocking inbetween the joists? The josts are just over 4 meter (13 foot) in lenght and screwed into the joist hangers. Is it to avoid distortion or to keep it more rigid?
you have a pretty cool space
Thank you Bigdukaaa :lol:
s123
Norway
Like this to keep joists from twisting under load.
A retractable staircase for the loft would be cool .
Thanks Jo Diesel for clarifying. Seems to be a good idea to make the construction more rigid!
Regarding the staircase, i have already got hold of a used one. It is actually visible in some of the previous pictures. In the picture below you can see it next to my trailer.
It is made out of glulam so it is rather heavy. I'm not sure if I'm able to make it retractable.
s123
Norway
Before putting the floorboards (chipboard?) up I have decided to paint the underside of them as well. This is just to make the ceiling brighter and maybe get some reflection of the lights. So the floorboard were stacked against the walls and luckily I got some very good help to paint them. Thanks a lot!
dubber
Canada's Capital
Wow, this is a very unique project. The aerial shot really helped put this all in perspective. Good luck with the rest, I'll be eagerly checking back.
s123
Norway
Thanks a lot Dubber - I'm quite pleased with the opportunity. Now it is all about finishing up before the winter sets in.
s123
Norway
Been working with the mounting the chipboards for the floor of the loft. It was more timeconsuming than expected.
I had been somewhat optimistic by putting up all the joists in advance. Even if I got the measures right, it did not work out that way in real life, because it was impossible to get the boards perfectly connected together.
The last third of the joists I have to space out to compensate for the imperfection. The boards is also somekind of heavy to deal with on a ladder as well, so I'm looking forward to finish this up.
s123
Norway
you are supposed to run the flooring the other direction. Lengthwise across the floor joist not with them.
My bad - In a hurry with little experience I just lay the flooring without considering the direction.
I talked to a building engineer about the impact i would put on the floor and he said that the weight I'm gone have up there will make no big difference, so I decided to leave them like they are.
s123
Norway
So - after a total havoc of my cellphone - I lost most of my pictures, but have been able to recover some of them. As I mentioned I got hold of some used stairs. It was I little wide so I decided to narrow the stairs and give them a lick of paint. Selected gray for the steps and white for the sides.
s123
Norway
So, next step was to create some railing on the mezzanine and the stair leading up there. I decided to make the lower part of the railing on the mezzanine to be removable. This will make it easier to put large items up there, but will also make the mezzanine floor a steady work plattform for me to polish the roof of my Hymer which fits neatly under there.
rubberrodder
Tacomatose Wa.
Very nice work so far.
Personally, I would add a support beam under each floor joist. Maybe it would be considered being "over built" that way, I just don't like the thought of the mezzanine dropping down on the other projects below it. But I also tend to "over build" stuff.
s123
Norway
Thanks for your comment! The mezzanine is also bolted to the walls on three sides. The engineer I consulted advised me to set up support beams only on the left wall in the pictures, but I put them up on both sides, just to be sure. I see your point by supporting each floor joist, but it would probably be over engineered and I have to consider the amount of wight I'm putting up there. It will be mostly interior details like carpet and seats stored out of the way of welding. I have a another storage for engines and gearboxes and other heavy stuff.
*JJ*
Texas
Great project...I like the fact you're leaving much of the original graffiti on the walls. Looks like you'll have a really nice space when it's completed.
ChaksQ
I'm digging the space and your customizations. Especially the loft construction. Seems you have a cool opportunity with the split up larger space. I'd love to find something like that myself.
I'd also like to see your Hymer. Have you done any modifications to it?
s123
Norway
Thank you. It have been different opinions about the graffiti. I think it is cool, but it was quit dark and disturbing the surfaces. I have come to that age when I need good lighting to be able to work properly, so I'm pleased with painting most of it in white and keeping the green door with the decorations.
looks great! do you have a pic of your hymer?
jim
Thanks! Pictures of the Hymer below :)
Thanks. I'm very pleased with the solution. The loft will be great to store stuff dismounted parts when restoring / welding on cars below.
The Hymer I bought in the autumn of 2015. I have not yet done any major modifications to it, just used it for week end tours and a good long holiday touring in Europe last year. It is a 1990 Mercedes based car. It is a 550 (5,6 meter long) with a total weight below 3500 kilos. It have the 5 cylinder 2,9 OM602 diesel engine (no turbo) and a manual box.
I have some plans for it though. I have a couple of OM602 turbo engines from the 312 sprinter and the E-class 290, but they are quite different and will require some modifications to fit and work. I also have some non turbo OM602, so I will try to pair them up and see if i get something working. Maybe I will put up a build thread during the winter for this project.
NewShockerGuy
Northern Virginia / DC
Nice progress. I was sad to see that you painted the walls white. I get the functionality but in terms of color and having something a little different the graffiti was really cool looking. Now it's just plain/boring/same...lol No biggie though.
How many other people have spots in the building?
-Nigel
s123
Norway
-Nigel
We are 6 persons that have got together to rent a small part of this factory building. I found a sketch we used to illustrate where to create the doors etc. It is completely out of scale, but can help to give a indication of the floorplan.
Most of the walls were already up. I have the bottom right section (the smallest one). Next to me there are 3 guys sharing the largest area, and two other guys have a section each. There are also a partial second floor (you can see the stairway at the left in the drawing, where we have individual storage spaces. Mine is approximately 20 square meters. I have not posted any photos of this area.
We have the advantage of being a community so we can help each other out, but also have restricted access to our individual areas (except the one next door to me where the three guys have one large common area). It is also nice to take common coffee breaks and do some ******** chatting :)
madoc1
spicewood, tx
nice size rv. would like to have one like that. thx for the pic. i f you do a build on it let us know.
jim
M-technik-3
Western Mass
Love the idea of repurposing a building, seeing more of rehabs here in the NothEast now that the economy has revived. People have breathing room in their wallets now that fuel is has come down in price.
Keep the updates coming, I would imagine your Summer is starting to get shorter significantly daily. I was in Varnes last winter three times with USAF doing shuttles of the US Marines bringing in -53 helicopters and outbound trips with them.
s123
Norway
jim
Become vary found of the Hymer. If I do a build thread I will for sure post a link :)
Will for sure try to keep up with updates. Even if I live in the southern part of Norway, the summer is on the move, but then again will give more garage hours ;)
welder57
Would you please give us the locations of where the pictures were taken? Love the country sides and the lake is very beautiful as well. You have done a lot with the place, keep up the great work!!!!!
s123
Norway
Thanks welder57 - I guess you mean the Hymer pictures above? They are taken at following locations:
Pic 1 - At the ferry dock in Rødby Denmark, waiting for the ferry to bring us to Puttgarden in Germany.
Pics 2, 3 and 5 are taken at Høvringen in Rondane National park in Norway. They are taken early in the autumn.
Pic 4 are taken at Ørje Sluser in Norway, near the swedish border. I do not know if sluser translates to sluice (?!?) Anyway here is a video of a boat ending up at the spot the picture is taken.
The last picture is from a vineyard in the Mosel Valley in Germany last year when we had a terrific vacation last summer.
