Outlet Mounting in Metal Building
Sgt_Oddball
Denton, Tx
Just planning out the wiring in my new workshop. Laying out some EMT conduit and boxes etc. Im trying to keep the outlet faces flush with the front of the C section. Anybody see any problems with the layout in my pic? Nothing screwed down yet, its just laid out for example.
Also, any suggestions on running conduit past an I beam? Am I ok to just drill a hole straight through it or do I have to go around?
Thanks in advance :thumbup:
gregtwojeeps
Ky
They also make these that would work for you if you wanted.
TGSjr
That what I did in my shop
works good do not have to bed over to plug anything in
matt_i
SE Michigan
Personally I would not drill the red iron and would rather bend a couple of offsets around it in saddle-like formation.
Aceman
Eastern Oregon
I always ask the customer before drilling red iron. If no one knows if it's okay or not, offset around it.
We install boxes in metal buildings a few different ways depending on the install.
1. Bracket boxes work better than that setup you're using. Much simpler, just a little offset to get into the box. Going in one side and out the other means you can pull through a few boxes at a time.
2. Mount 4 square boxes right to the face of the Z channel with the top of the box sticking up proud enough to get a conduit into the back/side.
3. Mount 4 square boxes right to the face of the Z channel with the ko's lined up to drill right through the face of the Z channel where you can conceal your wire or conduit under the z channel. This is the hardest method because you have to strap your conduit/cable upside down and it leaves exposed screws sticking up.
