bulletpruf
Fellas -
Cut and pasted a pic from my build thread; could use some input on how to do this. I have limited experience welding. FYI - using a Miller 211 MIG with .023 Lincoln wire, should be 75/25 mix of shielding gas (argon/CO2).
So, here's a picture of the floor. Looking from the top of the car towards the ground (you can see the back wall through the floor because the car is on a rotisserie tilted at a 90 degree angle). As mentioned above, I was just cutting the old metal out of the way so it would be easier to get to the spot welds to drill them out.
And a view from the bottom looking up -- you can see the chassis legs that run underneath the floor pans.
And the money shot -- that's the driver's front floorpan that's been cut out. I bought half floor pans new, and they are long enough to cover the area where the two front seat brackets are (the ones closest to the cut out metal). However, I'm trying to figure out the best way to fit and weld it up. I'm thinking that I can cut the old floor again between the two rows of spot welds. That way, the old floor would be secured by spot welds in that area and so would the new one. Then I could **** weld the two together, or I could also try to put a bit of a flange in the new piece and lap weld it over the original section. Suppose if I did that, I could do a bit of plug welding in the overlapped area, too, but that might be overkill. If I cut it in that spot, I would not have to mess with removing and re-welding the seat bracket mounts.
Curious to hear thoughts or recommendations!
Thanks
Scott
Thanks
Scott
