which ratchet to get?
Adam.C
Not to belabor the point...I think if you can crack something free that's really stuck or tight, that's a big hurdle cleared. Obviously he's gonna need other stuff. So I guess I feel the difference in performance between a crappy Taiwan breaker and a Snap On ratchet of equal size and superior strength is greater than the difference between any normal sized ratchet and any other. Love my 3/8 drive snap On dual 80s, but they haven't really allowed me to do a job I couldn't do before.
What changed my automotive work was my Sears air compressor and impact gun. Now I use a battery gun most of the time. IMHO, that should be his first tool after a decent jack and stands etc.
Ok, IN GENERAL, when you look at ratchets, what I want is long and strong, maybe flex head, for reaching in tight areas and torquing stuff free. If you can get fine teeth, that's good in a long ratchet because it allows you to put the handle where you want. Longer the handle, the better it is to have fine teeth. Short ratchets don't need to be super strong or fine toothed necessarily.....
Once you crack a bolt loose, or when you are installing hardware, you want low back drag, so your ratcheting action makes the ratchet click and doesn't simply turn the bolt the opposite direction. A great ratchet, like the dual 80, is all of these.
What mechanics did in the days of yore is they had multiple ratchets, one coarse head for busting loose, and the fine tooth SK style round heads for removals and installations. You can still do that. Not every ratchet needs to be a fine toothed, low back drag, snap on beauty. Pros like them because it's faster to finish the job with one tool if possible. My advice is to focus on busting stuff loose first.
Modern ratchet makers, especially the Taiwan makers, don't seem to know the relationship between tooth count, strength and back drag. They seem to be blindly ripping off Snap On's ideas without understanding why. "Oh snap On has 80 teeth? We'll make 88! Mwah haha hah!" As if that makes the ratchet better. It's doesn't.
The question the OP should be asking is, "how will I remove a hub bolt, avcrank pulley, brake backer bolts, upper strut mount? " Hell, how will you remove your lug nuts? Can you do a brake job? Can you replace rotors? Start there, and ask someone like M6er how he does it. He and I are kinda in the same boat maintaining our personal or families fleets. Then you'll know what you need. No need for us to debate the subject for you. Might be a good idea to start with the Haynes manual.
markw365
I have the 4 ratchet gear wrench 120xp set which is a hell of a deal. I also have an flf80 flex head Snap On. For starting out, the 4 piece set gets you 4 ratchets, yes the head on the stubby is HUGE. But the set is a great bang for the buck. I'd also pick up a used flf80. The gear wrench, KD and other sockets are good. Just watch the reviews on stuff here on the forums.
Here's what others have recommended and I'll 5th them.
https://www.amazon.com/dp/B00BTEXPDK/?tag=atomicindus08-20
Citation
Indy
I would suggest getting the 72T Husky chrome ratchets as your basic ratchets. They seem to have the old Sears like attitude towards fixing things. The ratchets themselves are Apex and share the same basic design as the Gearwrench 80-some odd tooth ratchets. I prefer them over the Husky 100 tooth (a 120Xp clone) for three reasons. First, they seem to have lower back drag. Second, they have a thinner head profile. Third, the Husky 100 tooth has a painted finish. No, it doesn't hold up. Aside from a few extra teeth, the Husky is just as nice and costs less too.
Next, I would supplement the Husky ratchets with a set of Crescent or Napa roto ratchets purchased from Ebay. For right around $25 you can get a set of roto ratchets that are identical save for the plastic part of the handle as these GW ratchets
http://www.homedepot.com/p/GearWren...gclid=COiw86Cgz88CFQgaaQod_58Afw&gclsrc=aw.ds
(I'm not linking to the auctions because I can't vouch for the current sellers).
I picked up a set of these based on the suggestion of a mechanic friend. Yes, they are really handy.
Finally, I would suggest picking up one of these:
https://www.walmart.com/ip/Stanley-...75035&wl11=online&wl12=36132572&wl13=&veh=sem
GJ thread on the Husky version (rebagged, same tool)
http://www.garagejournal.com/forum/showthread.php?t=95809
Sometimes that long 3/8" is nice to have. That last one would be at the bottom of my list but still nice.
Yes, you could go SO but I'm not at all convinced it's worth it for most shade trees. You are better off putting that money into other tools.
lbhsbz
Long Beach CA
Find yourself a snap-on hard handle 3/8" swivel head...you'll never have the desire for another 3/8 ratchet, except maybe a spare.
Rossco
Great White North
I basically use 3 ratchets to make $$$$.
1/4 - 3/8 - 1/2 rebranded CAT standard length. It's funny as I lost the 3/8 about 3 year ago and got the CAT guy to replace it. My old 1998 SO was reinvented until the new one turned up.
H
homec
My desires have changed a bit so I'm either going to do this or get 2-3 used snap-on, depending on what's on ebay/CL. But the GW 120xp seem to be getting very good reviews.
92integra
To op I would pick up some of the new harbor freight pro series ratchets your not going to beat them for the money and life time warranty, you won't feel to bad if you lose one unlike if you loose any tool truck spec ratchet
Sent from my Z970 using Tapatalk
gdocktor3
Connecticut
Do you have socket sets? Gearwrench has a great bogo deal on 3/8" and 1/4" sets for just over $100, which include standard and stubby length 3/8" drive 84t ratchets and standard 1/4" 120xp ratchet to get you started. http://www.ntxtools.com/network-tool-warehouse/KDT-80550F.html
sk farmer
nd
I have several stubby 3/8 ratchets. They are very dusty from lack of use. The compact 3/8 however see very frequent use.
Unless you wish to impress your buddies I see little advantage to the standard size dual 80. There is no shortage of variety in quality 3/8 ratchets. When you can add several different ratchet styles that are as good or nearly as good as the dual 80 for a fraction of the price it makes no sense to get all hung up on them.
One is far better equipped with a compact, standard length, long and long flex ratchet than one dual 80.
555
Nomad-Arkansas & Georgia
The best ratchet is the one that feels the best in your hands and is not something you have to worry about failing and hurting you when it does.
I agree. It's an older Craftsman (USA) for me. I'm going to guess everyone on this board will have almost the same answer, just change the brand.
gdocktor3
Connecticut
The best ratchet is the one that feels the best in your hands and is not something you have to worry about failing and hurting you when it does. For me, that's old school Snap On hard handles. I don't much care for their new style comfort grip.
Good advice, definitely, but how does one know which feels best if having never used certain brands/styles? I thought my round head Craftsman was great until I got a Wright superrratchet. Though my 36t Snap On was amazing, until I bought a 120xp. Thought that was amazing until I bought a dual 80. Thought that was the perfect ratchet until I got a flex head dual 80. Then qr flex head dual 80. Now we have Proto/Mac 90t ratchets and 100 tooth round heads. Basically, a large plethora of different style/brand ratchets is the OP's best bet. To be acquired over time of course... Remember, you can never have too many.
