Hello all, I have a 32x28 13 foot ceiling well insulated garage. I also insulated under the slab and installed four 250' runs of 1/2 pex. I purchased a Nibco hot water floor heat control board and pump system. I have a open loop system now with a 50 gallon electric water heater as a hot water source. I am limited to electric only. I have tried this system the past three years but have always stopped using it because of the high electric cost during the winter months. I live in midwest Indiana. The cost of my electric bills in Dec for the past three years has been $600 to $800. In 2014 I had a new 18 seer 2 stage heat pump installed in my house with a new variable speed air handler. I then installed my old forced air electric furnace in the garage to use as the primary heat source. I only keep the garage at 45 deg F unless I am going to work out in it. My question is. Is there another electric hot water heating source I can use for my Hot water floor heating system? I have thought of trying two 50 gallon electric water heaters in series or a wood pellet boiler. I can not install a outside wood boiler or have a propane tank either.
