New 24'x24' Bungalow Woodshop/Autoshop in California
Huxley
Colorado
What is the deal with the random appliances? Can we expect a kitchen remodel in the near future?
N
nitro3421
N
nitro3421
Finished up my outdoor dining room table project.
The finish on the table top is:
-Minwax gel stain diluted with mineral spirits
-2 coats of two part Smith & Co. penetrating epoxy sealer
-3 coats of Wood Kote Ulta Flagship 450 Satin sealer
-Sanding in between each coat
The finish on the aluminum frame is:
-Raw milled aluminum sanded with 150 grit random orbital sander
-Scrubbed surface with dish soap to remove all oil
-2 coats of Berchwood Casey aluminum black neutralized with water after reaction occurs
-2 coats of paste wax
richtersrodz
Waxahachie, TX
Wow.. I've been following along quietly.. But WOW.. Impressive.. Garage, gate, driveway, tool boxes, lift, and now the table.. Very nice work!!
N
nitro3421
Are you using Waterlox penetrating epoxy?
Looking good!
Not for this project, I used Smith & Co. penetrating epoxy (see my last post). I topcoated with Wood Kote Ultra Flagship 450.
I dont believe most Waterlox products are exterior rated. I did use Waterlox at my last house I built for a butcher block I made for the kitchen:
Thanks!
richtersrodz
Waxahachie, TX
Man.. once you go to the double fridge, you never want to go back!! We built one into our last place, and my wife hated to leave them. Our new (1915) place has a single fridge, and we are planning to rip out the whole kitchen and redo it, just so that we can have our dual (one fridge / one freezer) setup again. With 4 kids, we can't keep enough food in a single shared unit. lol. Fantastic kitchen! Like the garage, top notch!
N
nitro3421
Finished up the driveway gate motor install over the weekend. Overall very happy with the setup. I used an inexpensive Mighty Mule FM500 motor:
Also made a quick ******** set last night. I'll paint it tonight:
N
nitro3421
Finished up the ******** set last night - turn out great. I ended up using some left over Benjamin Moore floor paint.
ttype976
Florida
Nice looking boards! Are you going to add a layer or two of Poly? It makes them a little slick at first, but if you buy real "corn" filled bags, the dust (once pulverized) will slow them down to the proper friction.
yeah, I've made about 8-sets of CH boards for friends & family in the past...I'm a CH nerd.
N
nitro3421
Looks good. Some reason I was thinking a more elaborate paint scheme.
Thought about it... then got lazy. Easy to add the traditional triangle shaped paint later.
I very well might clear coat them. Going to try them out as is for now using some corn filled bags I picked up from Etsy (tons of selection BTW).
what was the overall height of the gate post again, including buried depth.
10' (5' above grade, 5' below grade)
s2kattracks
Nashville, TN
Dang, Just got through all 25 pages. Amazing is simply and understatement!
I am in Real Estate, so I look at a ton of homes. Not many get this level of detail! Way to go on that!
Love it!
txusa03
Thanks!
Incredible attention to details. Whomever purchased you last house is very lucky!:beer:
drivesitfar
Nitro: place is really shaping up nicely. I sure like the new table you made, but I REALLY LOVE the butcher block top you made in your old kitchen's island. any chance you might have more pictures of it during that build and maybe telling me (us) how you made it?
keep up the great work.
N
nitro3421
Love it!
Thanks! My wife was in Real Estate for awhile too so I got to see quite a few homes with her, amazing to see the variation in quality.
Table came out great. I like your style.
Thanks, hoping to build more and even sell them for some extra $$
I've made many tables using similar reclaimed wood, I'll dig up some photos.
It was a lot of fun matching the original details of that 1912 house. The kitchen. For example you can see the floor in the kitchen matches the original floor in the 1912 portion of the house in the dining room. I matched all the siding, trim profiles, coved ceiling (not pictured), corbels, etc.
Thanks - it was a blast to make. I have TONS of pics documenting the process... I'll try to dig up and post.
Luke.jenner
Awesome Shop!
I am considering the same lift. Does it require a seperate constant air supply for the safety interlocks???
Regards,
Luke
N
nitro3421
Awesome Shop!
Regards,
Luke
You can lift it up without air, but you need air to lower it (to release the interlocks). Doesn't take much air.
N
nitro3421
Finally had some time this weekend to dial in the finish on the countertop. Hit it with 100 grit on a random orbital sander than put two coats of wax on it. Should keep it from easily rusting when I set something wet on it.
N
nitro3421
Picked up an absolutely massive Wilton bullet vise which needs a little bit of work. Does anyone know how I might go about replacing the end cap on the crank handle? You can see in the photo it's been jerry rigged. One thought I had was to weld on a large nut then grind smooth to match the other and the best I could. Open to ideas...
Model 101164
drivesitfar
Nitro: Wiltons are great vises and there are even better ones from pre 1950's if you happen to find one for the other end of that huge AWESOME bench you own.
i'm not quite sure what you are looking for unless you just need a dust cap which you could replace as simply as getting a $1 brass or aluminum freeze plug. i'd need more pictures to help more. or read this thread i started called Vise Repair 101 and post up a few questions asking about your vise there and plenty of helpful guys will help you including me if we can.
http://www.garagejournal.com/forum/showthread.php?t=252830
how wide are your jaws? 4 inch or bigger?
Redboy
twin cities mn
Got a lathe? Or a friend with a lathe? :)
Here's a good replacement handle...
That tubalcain's a resourceful fellow, and I like his style!
bulletpruf
San Antonio
Model 101164
Nice bullet.
GJ member KMScott has a website - wiltonviseparts.net. He makes replacement handles, replacement jaws, etc. VERY nice stuff. I have one of his handles on a 3.5" bullet that I restored.
Scott
N
nitro3421
Nice bullet.
Scott
Great advise and thanks for all the great resources guys! Looks like I have my fair share of reading up to do. No rush on this one but want the restoration to turn out well. I'll post some pics as I get started.
N
nitro3421
We're having a big Halloween party this weekend so it was a good excuse to get the place cleaned up and finish a few projects. Picked up these authentic Octoberfest beer garden tables from Germany. They'll be put to good use with over 100 guests coming. A few evening shots of the garage as well:
RXtacy
Rockville, MD
The garage looks fantastic!
Could you go into a little more detail about your gate hinge/bearing setup? It looks like you used pillow block bearings? Did you just secure your gate with set screws?
dittle fart around
Vancouver, Washington, USA
Those tables are great! I think I can see a German **** print on one of the benches.:beer:
N
nitro3421
Check out post #446 - top photo.
I had some solid rod (1" if I recall correctly) welded to the top and bottom of the frame. These rods slip into the top & bottom bearing plates. First I bolted a bearing plate to the concrete then dropped the gate into the bearing plate.
Next, I leveled the gate, and bolted the top bearing plate into the bottom of a 3/4" thick flange that was welded onto the gate post. The 3/4" flange at the top had 4 holes pre-drilled with some play in them to allow for adjustment to get the gate perfectly level.
Here are a few more photos:
You'll notice in this photo, I accidently made my gate post too short and in order to hang the gate, I welded a temporary plate on there and replaced with a proper extension later.
airmissle
Albuquerque, NM
This is an absolutely amazing thread. I just binge read the whole thing, it has given me tons of ideas for my upcoming build. Thanks for sharing!
drivesitfar
Nitro: i won't expect an answer before you have your party for about 100 guests, but one of the members is trying to install a stainless steel surface on top of about 18 feet of cabinets in his garage and wondering how to do it.
i know you tac welded the pieces together, but i can's recall how you attached the steel to the old doors you used as a base for it. sorry if you've already mentioned it, but i couldn't find it so if you wouldn't mind mentioning again could you?
also no hurry, but would still love pictures and you mentioning the process on how you built that awesome butcher block style top for the kitchen island in your old home.
thanks and good luck with the party
(yes those old German tables look cool too)
N
nitro3421
Happy to elaborate on the steel bench top install. Each of the 3 pieces of steel (14 gauge) weighs about 100 lbs. Given the L shape of the counter and all pieces being tacked together, I didn't fasten them to the door sub tops below. The weight alone of the steel holds them in place. If it ever does start moving around, it's easy enough to throw a few screws through on the turned down apron portion, directly into the doors below.
Here are some pictures of the butcher block process from my old house:
vonhef
Southern, Ok
This is really nice!!! :thumbup:
drivesitfar
NITRO: thanks for the 411 on the steel bench top. i REALLY LOVE your countertop and i need to make one. i also have found some old Ship Hatches from WWII that i'm going to do something with soon.
just a quick couple questions. is that Elmers or what glue did you use and how long did you have it clamped up? also what is the finish that makes it shine and protect it and about how often would you need to put on another coat? or how many coats did you put on in the first place?
thanks also for showing the routering out of the sink's hole.
VERY WELL DONE SIR!!
just curious what you might make out of this if you had a 5 foot long 27 inch wide 2 inch thick old ship hatch? i'm thinking of making it a small work bench that i have a metal cabinet to put under and then putting a 1920's Drill press on one side and a 1920's Prentiss swivel jaw vise on the other and use the bench for my light duty type stuff.
N
nitro3421
The glue is Titebond II: http://www.homedepot.com/p/Titebond-II-16-oz-Premium-Wood-Glue-5004/100144210
The finish is Waterlox. 4 coats on the top and 8 coats on the end grain in the sink. http://www.woodcraft.com/Product/14...atin-Qt.aspx?gclid=CNupi7vjhdACFQ52fgodOsYDfA
Great rustic looking wood in that ship hatch. If it were me, I'd make a tube steel frame to fit it and pick up a couple of vintage wood crates and turn them into drawers below the ship hatch top. Gorgeous vise!
