pendragon1998
Aluminum or pot metal (non-magnetic) pulley on a 1/2 in shaft with a flat. 1/2 HP motor is from 1953. Removed set screw. I don't think there is a key. I have 1/8" clearance (barely) between the pulley and the motor frame. Sprayed PB blaster in set screw hole and up shaft for a few days.
Built a quick and dirty pulley puller out of 1/4 steel bar from an old HF clamp and a 1/8 in work hardened steel scrap blade. Bent the bar. Built a better pulley puller out of 1/8 hot rolled steel channel. Bent the channel and the pulley won't move. What now...fire?
