Shiftless
Do any of you remember that Bill Murray movie, Groundhog's Vise? When I bought this today I couldn't help thinking that I had just done that.. Whew! Strong Deja-Vise, man.
Great movie! I could watch it again and again...
Is it my imagination, or is the slide unusually short?
Good eye, Mark!
I was struck by that as well, but it appears to be unaltered. There is still what appears to be original paint on the end of the slide. As a result of the short slide the throat depth is fairly shallow. interestingly, dayid has a Yost 44 pictured on his site, and the slide does appear proportionally longer.
http://vise.dayid.org/vise/yost/
Maybe Yost wanted to market the 43 1/2 as a compact vise?
Take a pic of the end of the slide.
Here it is.
The jaws are 3 1/2" wide, as one would expect, and the jaw opening measures 3 3/4"
After looking at some other 43 1/2s on google images, it does look like this vise was shortened. Whover cut it did clean work.
It is a bobber! Oh well, it'll still meet my needs. Now I'll be on the hunt for a donor vise. And so it continues...
Another! 2 in as many weeks!! I still don't have a flush mount for my versa--just sayin'. . . . .Do any of you remember that Bill Murray movie, Groundhog's Vise? When I bought this today I couldn't help thinking that I had just done that.. Whew! Strong Deja-Vise, man.
Here it is.
Anybody need any Wilton 9300 parts? Just got a nice one today with a cracked static/body. The rest is very nice. No swivel
Maybe keep them full circles, do a cutout of one so that there would be little parts areas, like on the stand KMScott just made for his Parker?Worked on my vise stand a little
I was going to use a 5/8" thick plate i got for free for the top plate of my vise stand but it's just going to be too hard to cut. It also would take a lot of cleanup. My plasma cutter only cuts up to 3/8" and I don't have a torch.
So I stopped at the steel yard and found these 1/4" circle cutoffs. 16" diameter. Just need to edit my design a little and start cutting it with the plasma cutter. Then I will stack and plug weld them together.
It's a bit beyond that. A previous owner was a welder; there are many weld holes and splatters on and around the jaws. The back slide was used as a anvil, and there are dings/hammer marks/and chips in nearly all exposed surfaces. I would have to remove substantial metal and repaint with several coats to try to cover up the bad. I plan on using this as a working vise, so the bare metal is fine by me.
Another member pointed that out as well. This has 4" jaws, opens to roughly 10", and weighs in at 39.87 pounds, not the 6" 160 lb, swiveling vise that the number scheme would suggest. The lettering, front knob, and jaw style dates this is from 1914-1920(ish).
Interestingly, there is a slightly raised cast rectangular area around the "26". The 6 is not cleanly cast like the other lettering; there is no doubt that it is 26. The font and base are also slightly different than other models I have seen...as Hollands are not as common as Reed/Prentiss/Charles Parker/etc its hard to find many pictures of the same or similar model.
I was talking to an old timer a while back and he suggested that this may have been a transitional model. In 1924 the style changed a bit and the numbering scheme was standardized.
CRS: i hope you paid more than $5 for this one, but it really doesn't matter what you paid for it. WELL DONE!!
you had to have a very nice Estate sale company or seller to let you hack away at the old work bench for that long. now those are the pictures i'd like to see posted cause i have spent more than a few minutes getting a vise off an old bench while 50 guys made comments walking by me (good and not so good).
i don't have one of those flush mounts or that little one that adds on to either to give it a few more angles. i think i'm missing the pipe jaws on both of mine too, but i think i might have a pair of pipe jaws i found without a vise in site a while back that might work.
i guess MBS is hoping Christmas is going have a red or orange piece in a box for him? is he your little brother??QUOTE]
Drives: These estate sale companies must be talking to each other. This time I had to pay $24 for the whole shebang. No benches were damaged in the extraction of the flush mount just a few scraped knuckles. Apparently the guy bolted the mount to the top and sometime later when he added some understructure for something else he ended up burying the nuts. Luckily he only used two bolts. Unluckily they were in the rear holes. Luckily one of the tools for sale was a keyhole hacksaw. Unluckily it was dull dull dull! I was finally able to cut the heads off the bolts and use the crow bar to pry the base up. If these guys don't stop mounting their vises incorrectly I'm just going to stop buying them.
Yes, mbs is my younger brother and yes he is hinting about the flush mount. I think I'll give it to him this time so SHHHHH.
MB
That Hollands looks good for a user. That handle looks off to me as well. Hollands have oversized balls exactly like REEDS, check the example that was posted, balls are twice the diameter of the handle. Yours look, well like normal balls![]()
Here's an interesting CL vise ad that I stumbled upon...
http://bgky.craigslist.org/tls/5853499270.html
Here is a makeover I just completed on a 1977 Wilton C0.
I have a Wilton bullet with a 76 date, it has the pins holding in the pipe jaws. I cant find the original pins anywhere online its like they dont even offer them.... anyone have a source for then?
Craptsin what size jaws does the 29X have?
3 1/4" quite a heavy vise for such small jaws.Craptsin what size jaws does the 29X have?
