Side box or top box?
JUNK-MAN
PA
I have the box in my avatar (obviously) and am quickly running out of room. I would like to add either a top box or a side box with drawers but after searching craigslist and ebay seem to be equally hard to find. What do you think is better option? The only real gain of a top is the space saving aspect of it but all the tiny drawers are just a pain. I like the idea of a side box a little better but it seems finding either are going to be close to impossible. Thanks
Tim37
I'm guessing that's a krl756 if so snap off still makes the top and side cabinets
gdocktor3
Connecticut
I'd rather have wide, tiny drawers of a topper vs narrow, deep drawers. My side cabinet was the last addition I made because I already have a 26" wide double stack & 33" wide triple stack and they're all full. My vote is a top box. You can find a cheap Craftsman or Waterloo topper for cheap on Craigslist I'm sure way before you'll find a side box. Unless you must have matching top box.
J
JUNK-MAN
PA
It don't have to match, but I would like a mac, matco or snap on much like the one the far right stack.
a52-830
north of boston, massachusetts
having the set (kr655, kr650, and kr290), i can tell you that:
1) tops are much more available than sides . kr555 (slides) and kr655 (roller bearings) appear identical, and match the bottom
2) the kr290 will match the drawers on your bottom, except the bottom two on your kr655 are combined into one really deep drawer on the kr290.
3) depending on how you sort your tools, it is likely that the large drawers in the top will be more valuable.
4) a side(4000ci, 1200si) will likely cost more than a top (11000ci, 4500si), so no matter which way you look at it, the top is three times larger.
i would go for the top first, it will be cheaper, and easier to find. if you come across a side you like, pick it up, that never seems to be a bad move.
Tim37
Well if your not super hung up on having. A match set then I think it boils down to space. Do you use the top of your box? If yes I would go with a side box that will give you that much more top if no I would go with a top box that saves floor space.
I do see both on cl evey now and then just keep a eye out they are usually fairly reasonable when they. Pop up.
bsg1
so cal
if in the long run you intend on having a side box and a top box, consider buying the one that comes up first at a price you can't walk away from. if i was burdened with having to choose between the two, i'd choose a Snap-on top box of same time period as the bottom Snap-on box.
crewchief888
NW indiana
all depends on what you need to store, and how your box is organized.
i started with a kr 550/555b i bought new in '86
added the side box about a year later.
paid approx $1100 for the new side box.
i kept expanding with used trade-in's 2 more roller cabs, and several side boxes
good luck finding a matching SO side. i never saw many of them.
:beer:
J
JUNK-MAN
PA
I think I'm going to end up going with a top because it sounds like it will be easier to find, my box is used as a work bench but not all the time as I do have a bench. I plan on at some point making it a set with a side and top but for the time being a top would probably work best. As for how I organize my tools the simple answer is, I don't. Although I did separate Sae from metric and put ratchets in another drawer. Does anyone have the dimensions of the kr 550?
J
JUNK-MAN
PA
Thanks
Agentwho
Baltimore
Top box's are far more popular than sides therefore you'll see a lot more used ones listed for sale. When I do see a side box pop up on cl they normally have a high price and don't sit around long. Of course everything comes down to timing. If you are not really pressed to go one way or another I would say just keep an eye on the local adds till the next good deal comes along.
Side thought, if you use the top of your bottom box as a work area and are thinking of a side box, why not just look for another bottom box. This would expand your work area and give you the most new storage. Everyone's needs are different but that is how I have my set up geared..
Good day
rsanter
visalia ca
Buy another snap on bottom that is similar to what you have ( same depth, same trim type)
Put them together and make a nice work bench out of it
Bob
a52-830
Here's a couple thoughts. I hung a harbor freight side box on my KR-557 which has the KR-537 top box. If I didn't have the bottom/top box, I would consider a montezuma top box with the appropriate footprint for the bottom cabinet.
http://www.strictlytoolboxes.com/montezuma-toolbox.html
does anyone make one of those "triangular" top boxes narrow enough to fit on top of a side box? say, about 12" or 14" wide?
crewchief888
NW indiana
I know I mentioned a top box but I spoted this CL ad, is this the correct side box or would it work ? The side box is on the right side along with a couple other boxes.
http://akroncanton.craigslist.org/tls/5885099289.html
none of them are the "correct" side box, but they will work...
the matching side box will be full height and depth of the roller cab
pictured on the left of the roller cab. on the right are 2 KR274 (?) stacked up
:beer:
a52-830
nice, dont forget the small box on top of the kr290 also.
i have only had the 290 for a few months, but it already is a place where **** collects. the workbench gets cleaned off, but i dont think to do it over at the tool boxes, which is why i have been thinking about something to go on top . . . .
J
JUNK-MAN
PA
[emoji481]
Nice set crewchief!
crewchief888
NW indiana
Nice set crewchief!
the small side box serves a different purpose now....
i had this set up at the last dealer i worked at, when i changed jobs the dealer i was at didnt have enough room for me to have all my boxes (or tools)
things got condensed i sold off one roller cab and the matching side box, and everything got shuffled around.
ive been in a service truck since '04, no room for anything bigger than a 26" wide box in the service body.
i kept all the side boxes, and the small roller cab thats behind me.
side boxes in the garage, and in my service truck, roller cab and another side in the basement.
:beer:
J
JUNK-MAN
PA
I have a side box, a top box makes me have to stand on a stool to see into it.
I don't think that will be an issue for me, I'm 6' 5" in boots lol. I'm actually leaning towards a top at this point do to how hard to find a side is going to be.
gdocktor3
Connecticut
I searched for a side box for months until finally finding the Husky for $75. One tip, when you see boxes listed for sale on Craigslist with side boxes, email or call them offering to buy just the side box. That's how I scored mine.
J
JUNK-MAN
PA
I like the way you think.
I see a lot more tops come up then sides.
I do have a Snappy side in stock, but I don't know what part of PA you live in.
I live some where like North Central, what is you're price?
Lookin4'67Galaxieconv
Atlanta, GA
Agreed on all points. :thumbup:
