Diva lite dimmable?
Dynomike75
As the title says, are the bees diva t8 led's dimmable? Just wondering. I will be installing 36 of them in my 1200sqft shop and was wondering if they could be turned down when I don't need all of the light.
matt_i
SE Michigan
I would not think so. The tube spec says 100-277vac. So if you dimmed past that voltage then the tube would probably just go out.
Personally I would wire them up to a gang of individual switches so they can be turned on in "layers". As in, put 4 on for basic lights, then up to 18 for the next level, and then finally all 36.
D
Dynomike75
http://www.beeslighting.com/product-p/t818w1200bixxdf40f1.htm
These are the ones I was talking about. If they really are James lights, from what I found, James lists all of their lights with internal drivers as dimmable on their site.
@matt_i, I was planning on putting them in like you described, 6/15/15, as well. I may just do that route, but while I was wiring, I was thinking about using a dimmer switch instead of a standard one if it was feasible at all.
Jawgarage
Near Cape May, NJ, USA
DynoMike, sounds like an awesome workshop......are these lights LED's?
What fixtures are you using to house these? I've heard great things about DIVA lights and frankly am lost in all the comparisons to others. I am doing a 32x50 garage that is basically in two halves, and has one bay with a 14' ceiling for a car lift. Going to need to buy the fixtures soon and I like what you are doing but need some more info. Thanks
D
Dynomike75
Thanks @Jawgarage, I hope it turns out. I have a 2 post lift (Atlas 9kPV), going in as soon as I finish up the hydronic floor heat and epoxy flooring. I am ordering the lights today, but am off to PRI next week so I don't imagine I will finish them up for two to three weeks. I will have the floor heat done this weekend and will get the lights up, then epoxy. I can take some pictures once I get the lights up.
Here it is pre-floor and apron about a month ago. The yellow is Creatherm insulation with the tubing pressed into it for floor heat.
D
Dynomike75
I am using the LED T8 bulbs mentioned above along with the fixtures from Bees (the 2 bulb with no ballasts). They are the two mentioned in the Best Fixture sticky (post 1) from Bees. I am going with those because of the quantity needed and the others require quantities of 30 at a time. I will be dropping them about 6" from the ceiling height, but may mount them directly to the ceiling once I get that installed. Right now, it is just open trusses.
I probably won't get the ceiling and insulation installed until late spring. At that time, I will do blown in insulation in the ceiling and add a split ductless system for A/C.
D
Dynomike75
Thanks @cybrdyke, do you know where to find that information? This is from James own website, which led me to believe they were:
Basic Data
Model number:ZY-T8-18W1200
Power consumption:18 watts
Led number:120 pieces of SMD 2835
Dimension(mm):Diameter:26mm Length:1198mm
Weight:367.4 g
Lifespan:50000 hours
PC cover:Transparent/Striped/Frosted
Power factor:0.99
Certificates: cUL,UL,FCC,DLC 4.0, NSF
Can be dimmable and non dimmable
Fa8 lamp base,G13 lamp cap base and rotated cap base available
cULand UL Listing File number:E358903 and E358956
Input Voltage can be AC100-277V or AC100-347V
Optical Parameters
luminous efficiency:more than 140lm/w
luminaire efficiency:90%
Color Temperature:
Warm White: 3000-3500K 2520 lumens
Neutral White: 3500-5000K 2520 lumens
Cool White: 5000-7000K 2520 lumens
Electronical Parameters
Input Voltage: AC100-277V or AC100-382V
Frequency:50-60Hz
Power Supply Efficiency:90%
PFC:>0.99
Other Parameters
Operating Temperature(-20-50℃)
Stock Temperature:0-50℃
Main Material:Aluminium Base + Aliuminium Housing
Life span:50000 hours
cUL and UL certified Led T8 tube light
1) cUL and UL certified approved led T8 tube light
2) 140 lm/w,AC100-277V or AC100-382V,PF>0.99
3) Aluminium base and Housing
4) clear/frosted/strip
5) UL Code:E358903 E358956 UL standard:UL1993,UL8750 and UL 1598C
6) Warranty: from 5 years to 10 years
Packing Detail
Inner Box:Diameter:40mm Length:1220mm
Outer Carton : 1250mm*210mm*230mm
25 pieces in a carton.
Net weight:9125 g Gross Weight:1130 g
Advantages
1) Energy saving about 70%;
2) Long life spane more than 5 years;
3) No infrared rays, no ultraviolet radiation, no thermal effect;
4) Ultra slim and unlimited design and various dimensions are available;
5) Soft and wide light emitting;
6) Special circuit design, avoided the single broken LED influence problem;
7) High efficiency constant current drive system, with heat protection system, can work under unstable voltage;
8) Instant start, no flickering, no humming, no RF interference.
D
Dynomike75
@cybrdyke
Ok, I believe that I misread the part number of the dimmable ones, you are absolutely correct, the magic tubes are not dimmable. Thanks! :beer:
