My 45' X 30' pole barn
djkilgus
Central, IL
We just moved into a new (to us) house July 1st and with it came a 45' X 30' Morton pole barn. Over the past few weeks I've been installing horizontal studs and rewiring the entire building to support its future use. Yesterday I had open-cell spray foam installed throughout the building. I have a Superior Radiant 20' UA 60K BTUH Natural Gas radiant tube heater on its way.
Our stuff (in preparation of the insulation).
I've added the horizontal studs & framed the 4 windows.
This is where my sub panel will go.
This is where I'll have most of my light switches, fan switch, garage door openers, etc...
D
djkilgus
Central, IL
Here are some post insulation pictures. The top half (above 8') was painted white. The bottom 8' is the natural color of the insulation. I'll be covering the bottom 8' with 1/2" OSB.
JackB1
Nice job!
I have heard good things about Morton!
I got their catalog and will get a quote on our next property purchase.
Any pics of the building before you started? Pics outside?
Thanks for posting!
Best!
Jack
WJ MARK
If you don't mind me asking what did it cost for the insulation??? Im really thinking about doing that in my 30 x 50 but havent called on any pricing yet??
Thanks,
Mark
GHOSTDANCER
D
djkilgus
Central, IL
Nice job!
Thanks for posting!
Best!
Jack
No pics before, the guy we bought it from put the building up. I do have some outside pics I'll throw up when I get home.
D
djkilgus
Central, IL
Thanks,
Mark
It cost me roughly $3500 for the insulation & I think about $300 or so for them to paint the top half white.
Ezzie
Lake Chapala, Jalisco
Just curious why you selected open cell foam instead of closed cell?? Won't you need to put a vapour barrier over that foam before installing any sheeting?
D
djkilgus
Central, IL
The main reason I chose open versus closed was price. Comparable closed cell would have been about $1000 more. They guy that did the foam said that in his experience the vapor penetration was negligible and I wouldn't have to worry about it. I'm putting OSB on all the walls and am not concerned about moisture. It's a risk I am willing to take.
D
djkilgus
Central, IL
These pics were more of the enormous tree trunk I got rid of and not the shed, but you can see the shed in the background. As soon as I get my sub panel finished (today I hope), I'll put some pics of the wiring job and the front of the shed.
D
djkilgus
Central, IL
Just subscribed to this thread, as I plan to build a 32 x 48 shop in the future, love how this is turning out.
Great work.
I hope my thread helps! I plan on trenching water, natural gas, and upgraded electric (currently 20AMP 10/3, moving to 60AMP 6/6/6/8 (not sure that's how to note it)). Also plan on putting in workbench, shelving, ceiling fans...
Motofixxer
If you plan to upgrade the electrical, I would recommend just using regular aluminum Service Entrance Cable it's 2-2-2-6. It's large enough to easily upgrade later and won't have any voltage losses as long as you stay on the charts. You might find later you want a really nice 7hp compressor that pulls 30a all by itself. Then with lights, heat, couple power tools...you start running out of power quick...
roaddog359
Northwest Indiana
I was in the process of starting my 30 x 48 Morton building, until my wife got laid off her job. She may go back to work by March 1st I hope. If that happens I will try and start my build then. Keeping my fingers crossed she goes back to work. Damn economy!
jonnysteals
What is that heater. never seen one like it before. Maybe some details and a price. Thanks looks great
D
djkilgus
Central, IL
I purchased the heater from these guys: http://www.infraredinfo.com/superiorradiant.html. I think it was just under $1200 shipped. That included a thermostat and hanging chains. I have yet to fire it up (currently trenching natural gas out to the building).
My dad used to work at a fertilizer plant and they had one of these (bigger model) in their shop. When it fired up it heated the building up pretty quick. I plan on keeping mine on all winter. Haven't figured out what I'll set it on, but probably somewhere in the neighborhood of 45 - 50. I went with radiant because I have 3 garage doors, 4 windows, and a walk-in door and didn't want to lose heat while I was working out there if I had to leave a door open for a while. After reading up on convection heat versus radiant, I was convinced radiant was the way to go.
I hope to have the water, NG, and electric ran by the end of the weekend. I'll throw some pics up when they are done. I also hope to be able to tell you how toasty warm it is sometime in the coming weeks!
D
djkilgus
Central, IL
It took a little longer than I had planned, but there is now heat. Just in time for the Illinois winter. Here are some pics:
2 trenches. Left one for water & gas, right one for electric.
This is where I tapped into the cold water supply in my house.
My contribution to global warming... cap and trade that Pelosi.
Gas supply coming into the garage. I used 1" in case I wanted to add additional NG things in the future.
Exhaust. Type - B even though I didn't need it.
The completed loft. 30' wide, just over 8' deep.
Finishing touches on the heater.
3/4 inch PEX for water supply.
Switches, spots for garage door openers, & wires for fans.
Subpanel
D
djkilgus
Central, IL
A couple other things to note. I've kept it @ 45 degrees and that seems to be about right. It's been relatively mild the past couple weeks so we'll see how things go when it really gets cold.
The other concern I had pre-heater was the positioning and evenness of the heat. I was worried that by putting it perpendicular to the length of the building in the middle that the garage wouldn't heat evenly. So far the heat is amazingly even. When the heater is running it's obviously warmer in the middle of the garage, but overall the heat is pretty even throughout.
Fueler
Urbana, IL
Once you get "stuff" in there it will be more warm and even than now and have less run time.
D
djkilgus
Central, IL
Here are pics of the workbench I just built. 2 - 8' X 3' workbenches. 1 of them has a shelf on the bottom. They are approx. 36 3/4" high.
ARTEMIS1759
Radiant and floor are the most efficient. Been in garages and shops that use one or the other...All I have to say...Amazing.
TomCat1
Illinois
What do you mean approx, 36 3/4" high? Could you go out and get me a more specific measurement? Ha Ha! When the bar going to be open?:beer:
articsilber323
maryland
while your garage is 45' deep im looking into building a 20X42 and was wondering if its enough room to park 2 full size suv's (Cadillac escalade esv the big one) one in front of the other ?
D
djkilgus
Central, IL
Can you give us any info on the heater? Size, btu, etc? Where did you get it? Thanks.
It's 20' long, 60,000 BTU.
I've had it running for a couple months now and absolutely love it. I'd highly recommend it if radiant in the floor is not an option.
D
djkilgus
Central, IL
How did you fasten the horizontal studs to the poles? Did you screw them in or just toenail some nails in?
I toenailed with screws. 2 on the bottom and 1 on the top of each 2x4. It actually worked pretty well. My dad did the same on his shop so I knew that it would work. Having the foam sprayed in afterwards really helped firm everything up, but even before the foam went in they were pretty stable.
