magnetic starter
dizheafta
Trying to find out if this is the correct magnetic starter to run my 5hp 220v saylor beal air compressor, it keeps tripping the reset button after a couple of mins.
LXCam
I'm with Matt. Normally the heater selection chart is on the inside of the cover.
D
dizheafta
Yes everything came with the compressor. The 5hp motor is a baldor L1430. Where can i find the part i need. Appreciate the help guys.
wyliesdiesels
Modesto, CA
D
dizheafta
I,got it used. I will order a e67 and try that. Guys appreciate it very much. Lots of good stuff on garage journal. Happy holidays.
D
dizheafta
It runs,but after a minute or so stops. Have to hit the reset after it cools down.
D
dizheafta
Yes it trips after couple mins of running. I think he gave up and went and bought a new one. I thank you for your help.
D
dizheafta
So discountfuse.com is backordered for 4-5weeks, anybody know where else i might find one and is the flat looking aluminum strip fuse made by furnas compatible?
wyliesdiesels
Modesto, CA
Norcal
Siemens bought Furnas Electric, so try a Siemens dist. or google the required heater size it may show up for you at a used electrical equipment dealer
D
dizheafta
Of course i have tried google, alot of places dont have a picture or its not the spring type. Does it have to be the spring type or can the flat aluminum one work?
