ard
Out of curiosity, are the garage walls and ceiling sealed? Meaning completely drywalled with no ventilation or air that can circulate and/or exit out of the structure?
Yes, walls & ceiling insulated, drywalled, textured and painted. Uninsulated garage doors. No heat or AC.
Location is northern CA, Sierra foothills. Low temps under freezing perhaps 5-10 days a year, but usually just a light frost. (Basically pool equipment and well head need no freeze protection with just a simple 3 sided structure over them.)
We have a wet-cool season and a hot-dry season. In the depths of the wet cool winter Id get the efflorescence and darkening. But as mentioned above, not much any more. BUT...CA is in the 4 or 5th year of drought.
The rear wall is cut into the existing hillside a bit- so the stem wall is up 24-30 inches, across the back and one side. The two areas that demonstrated the moisture pattern were towards the rear wall.
I may be looking at decking/tiles, or just repouring it. I need to cut out and excavate for a footing for a 2 post lift....whats the incremental cost of breaking it all up, fixing the thickness at the lift, rebar it all and pour. Although if I repour it all, still need to do something with the finish..... PITA.
thx
Subscribed Great job and thanks for sharing!!
