Love the old cat grader!
Also all the other work as well!
Dan, I have heard that story before..
Andy: you sure get a lot done in a day and amazed you still have the energy to post and spend a few minutes to post all the good comments. WELL DONE!!
I feel like I don't get much done, so thanks for the encouraging words.
My mother in law, before she passed, would always respond when asked what she needed, was "a few kind words". Wise woman.
so i'm wondering how you soldered that T to the left of the new weld/solder where you had the safety piece of metal and wood (BTW nice plan leaving that where you could find it 10 years ago)? i'm guessing you soldered that maybe over on a bench and then just did some simple extensions where you showed us and one on the other side of the wall?
Yes and no. The pipe is as long as the room plus one wall thickness, so I had to fish it in place without the tee. I like to do all three legs of a tee at the same time so I put a support under the pipe, fitted the tee and both branches (one branch with the threaded end fitting soldered on) and soldered them one the ladder about a foot from the wall. Then maneuvered the branch into the coupling and soldered both sides in one heat. The side of the wall with the stub poking through is part of the 15' 6" long pipe.
nice job clocking those screws and until i heard a couple comments about shop dust gathering in the grooves of the screws when they are horizontal i think that was my preferred method instead of vertical.
I just don't clock screws so I can't be criticized for not doing it right. If the slots are vertical that same dust may get into the socket which would be more of a hazard
i have a question on the safety factor of your CUSTOM holder for your pipe. since i'm guessing you cut the piece of wood in half with a bandsaw why didn't you continue to cut the trim out on a bandsaw too instead of a table saw? or did you make both cuts on the table saw? looks like it worked and i didn't hear you lost any fingers so another quality job.
I clamped two pieces together to drill, you can see the clamp in the picture. And I started the spur in the crack so I have exactly half a hole on each side. The kerf would have given me less than half, and I didn't want to use a thick piece of oak. The board is 2-1/2 inches wide and I'm too lazy to put a wide blade on my bandsaw for a few cuts. The narrow blade may not give a good cut in that depth oak so I elected to use the table saw. I cut the piece long to keep my fingers clear in the table saw. The piece is wide enough that a little of the table saw insert was showing so I could hold down and to the fence to cut, being mindful that if it binds it may be thrown back and my fingers have to be in a safe position. After cutting I trimmed the end off on the radial arm saw for the finished piece. Thanks for asking.
i still have a hard time looking at your plumbing and wiring, but it's starting to look more normal.
I DON'T WANT TO BE NORMAL
My wiring is not for general use, it is just something I have worked out and it works well for me. Running THHW in conduit would be very time consuming and costly, as well as not lending itself well to modifications. We had to run conduit in our church (5,000 sq ft addition I managed) and tracing circuits and modifying conduit in a hot attic was less fun than I had hoped. I had an electrician helping me, but he is an oil field guy, great on 440 three phase but had never done much conduit and never a three way switch. We also got into enough lights I had to get lighting contactors to take the load off the switch. A third of the add-on was doubling the size of a fellowship hall so all the new lights and switches had to interact with the old lights and switches like it was all built at once. Passed inspection first time (State Fire Marshal).
Here's a 360 shot of the church addition classrooms in progress http://www.360cities.net/image/new-construction-first-baptist-church-terlton
enjoy your Saturday today!!
Heart doctor today (nothing wrong, just small, hard, and cold) so I only got 1/3 day in, BUT IT WAS STILL SATURDAY
NED: nice post and i agree Andy's humor will infect anybody and make them feel better. GET WELL SOON!!
Are you saying I'm contagious?
You have a lot of wonderful old equipment! Your wires and pipes look great. It's a good job!![]()
Andy,
Love the electrics, just so different and well executed..
Have a good one..
Andy,
You too are in this group...
I know that I haven't been posting lately but I wanted to let you know that during the time we were in the ICU your thread, among others, help pass the time. Just thought a thank you was in order.
I will add, you make me laugh and that is priceless.
Cheers,
Chris
... It's home, set on blocks, downhill from any building, ...
The electric scheme is probably easier to take in my shop than in your shed, I would wager
I really expected to be thoroughly roasted by the way I'm doing wiring, but you guys have been very kind and reasonably understanding. Thanks to the group, those with positive statements, and those that hold their tongues!
(I'm doing it my way anyway)
In my broom shop I really wanted to run bare conductors across the ceiling on porcelain thimbles and hang pigtail light sockets from them with large clear incandescent bulbs from them and push button switches to get the 1900's look. Considered 12v. Add lights by reaching up and hanging more. I waffled, I chickened out, I'm a wimp. Taking the broom out of the vise I could catch a wire. But it would have looked so coolLike an electrical version of a line shaft installation.
Guys, thank you so much for your comments and visits. It means a lot.
And few people will know WHY this is important !
Andy, you are right, it wouldn't work in my shed, even though technically it would meet the code out here.
Seriously I do like what you have done..
Regards
I like your wiring in the shop I may do the same in mine if it ever gets built.
walt
Andy, the wiring has inspired me just so you know. I converted a small drive thru corncrib into my woodshop years ago. A double bypass on my arm that didn't work and then they put in a new artery from wrist to armpit that has worked well slowed my shop progress to the point I just used what I had in place. I originally though conduit, but the romex on that run and with the clips, FANTASTIC!, I really like the look and think for my woodshop it will go nicely. I hope you don't mind I "borrow" your idea, when asked about it will surely tell where I got the idea and who the original idea belongs to.
Oh, I finally understood your ability to "shoo" horses. Good one!!!!!!!!!!!!
What was your reasoning for going with copper over regular "black iron" as everyone on here seems to call it? I use the industry standard here of A105 and A106/B, it is really easy to find good leftovers at the scrap yard. Yep used air lines for me, like your bags of grain it is cheaper, but I like to call it being frugal.
JB
Andy: nicely done and BEE CAREFUL moving that big compressor. FAT COWS ARE HAPPY COWS and yours seem to be smiling. i also be they are good exercise to fit in with your Zumba.
Moving the compressor with Bob was where an issue could have been. Walking it across the floor is a piece of cake, you just start rocking it and then sliding it as it is rocking and vibrating. It moves very easily.
JB: i'm guessing maybe Andy had that copper sitting around waiting for a project. i know i have some sitting in my crawl space cause like Andy and a few others around here i hate going to a store in the middle of a project. i could be wrong though.
Guilty as charged, had very little tubing left from several modifications over the years. But I will have a lot now.
just curious if you have to cut and rethread the used black pipe you use and do you do it by hand sort of or do you have a nice pipe threader?
That's a cool old utility truck. Was there a trailer on the other side of where it was parked? I was going to say it looked like an old oil field truck?
Now that you have that c o e, you won't be needing the other?
1/2 pleased.
Andy, I am just so stoked that the Ford Script arrived safely.
As always enjoy..![]()
Andy
And all the way back over here - I have it's mate!
Lyndon
Still looking for mounting ideas. . . . .![]()
Well done boys.
Andy my vote is the COE build.
The 10 wheeler is cool, but I think the COE will be coolest
GB.
Nice score on the Ford Andy. Gotta love those trucks. (well you gotta). That was down(under) right nice of 1/2 to send you that. I've heard that he's a pretty nice guy. So what's your plan for the Ford? At you going to plant it and see if it fruits? It would make a real nice crop too. I'll take one when you harvest.![]()
I always enjoy checking in on your thread! There seems to be a lot of cool things going on here![]()
I can see all kinds of potential in the ole' Ford C900
Finished straightening up the wire runs
That's as good as it's going to get, they just won't straighten any better![]()
Thank you!! I'm still thinking of places I could display it! I feel 1/2 good about it!!
I know, I saw yours and drooled. Even though I suspected one might be on it's way to me, I couldn't really expect it. What a great surprise!
Unfortunately mine came with metric mounting screws so I'm sure my Imperial screwdriver will not fit it. Need to look around and see if I've perhaps got a Whitworth Phillips.
Down (under) right nice
I'm just about 1/2 happy over the hole deal.
I know you can see right through his gift to me.
But I like it, you know, anything shiny for a redneck (no redbacks were harmed in this production)
Thanks for the visits everyone! I guess you all know I waffle now and again. Too many interests pulling me in too many ways.
One more Saturday this week!!![]()
Note to file : 1/2 Cup you have really stuffed up here. Shame.Looks like, but that is just **** !
Way cool on the Ford sign from down under. Way to go 1/2 cup.
I know where there are a couple of the Ford COE's, one is for sale. I think they are both in the 60's, one has a wheat bed the other has a box bed. Good for storage!
I have a rocket launcher that would fit on one. Its a car hauler that goes over the cab and has a "stinger" to pull another. It had 2 winches on it , but the guy that delivered it took them. I thought I had a picture of it?
Andy,
The pleasure is all mine, let me tell you..
If you only feel 1/2 good about not having found a place to mount the Script my words of advise to you are to ponder the situation for just 1/2 a moment as we don't need any 1/2 baked decisions made at this point in time.
Metric mounting screwsNote to file : 1/2 Cup you have really stuffed up here. Shame.
One consolation Andy is that should you not have the correct screw driver, that it is a golden opportunity to buy more tools..
Can I recommend that you dot buy any Whitworth Phillips if you don't have one, they are just so yesterday type technology..
Shiny + Redneck just go hand in hand and you are right I can guarantee that none were harmed in the scripts manufacturing process but rest assured that process did leverage of some Redneck techniques..
Waffle ... never..
Enjoy..![]()
Andy, just fantastic....
I am sure the Ford Script will eventually find a home..
Cheers
That's the air line. Late in the day I put valves and plugs on all the connections (13) and pressured up the pipe. Three leaks, all three dry joints on one side. A little flux, a little heat, and a little solder and all three sucked up solder. Pressured it up again and no leaks on a soap bubble test
Ready to get the lines into place and add supports. I am so ready to have my air compressor back. Then I've got a little more wiring to do, lights to hang, and a little sheetrock work, build doors for the pain booth and finish up the exhaust fan and we're DONE!
Then I can start cleaning up my shop.(good one)
I can hardly wait. I've been following you around for months and now we're going to see you do something. I'm all ................fuzzy thinking that you are going to stop being lazy Andy
Oh yeah, the air line looks pretty good too. Did you steal that idea from me?????![]()
I want a big truck like that!
Bruce
Andy you can get special clamps from any Model A supply to mount a license plate. They will work for the Ford sign with a small modification. Looks nice. Bobby
Andy, I cannot imagine how productive you will be in the newly remodeled shop. Heck, you are building, fabricating and installing all kinds of parts around the mess of remodeling. Amazing. You are an inspiration. Oh, the Ford emblem, I'm thinking it would make a fantastic belt buckle for you!!!!!!!!!!!!!
It will be a new experience
Andy, your air lines look great the way you have done them, they compliment the electrics.
Are we polishing the copper lines per chance??
Regards
Andy, understand, polishing that copper would be a big job..
PS no package.
Regards
ANDY: sorry i've been lurking and admiring all the work you get done every day while you still have "CLEANING THE SHOP" on your TO DO LIST (or maybe it's a list in your head since you don't do TO DO LISTS).
I only have one goal, cleaning up my shop, I just needed a bit more space for a "place for everything".
i can't recall how you originally mounted the boards that your wiring is laying on. did you use a nail gun?
Strips are nailed to the sheetrock. Originally I glued and nailed them, but this go-around they are nailed only, with the nails angled outward to avoid pullout.
it's still growing on me and i love your new what looks like OAK brackets for your copper air piping. just curious since it looks like you are using a lot of heat to solder the copper pipe connections are you using LEAD FREE SOLDER? i remember using some when it first came out 20+ years ago when i replaced all our galvanized piping with copper that i had to heat it up almost to melting the pipe to get it to work. having 3 new babies in the house i really wanted to do it right, but there should have been (or maybe there was) a better way.
anyway now for any copper piping i do for outside plumbing i just use some of the old solder i find at garage sales that has some lead in it and it works a lot better. sorry i waited until you were almost done to think of this.
Now you tell me! I had forgotten about lead free, and that is what I had picked up. 95-5 Tin Antimony. It does take the heat. But as long as the joint draws it I guess it works. Hard to get a nice finish on top, though. I'll check my stock and put back lead bearing for future repair jobs where I have to pull a joint apart. I tried to pull the first leaker apart and could not get it hot enough so I capitulated and just added solder. Not an issue since it worked.
everything is looking pretty good and are you on schedule for opening the box with your lift in it on CHRISTMAS MORNING?
Grand scheme
cheers
1/2: with all you have going on you still managed to ship Andy a Ford sign. i still need to get out a few USPS boxes that i've got buried under my STUFF to members. WELL DONE SIR!!
