So, I know this isn't exactly for my garage...but I figured you guys are all pretty smart people and might know what I need to do to get a regular thermostat on my gas fireplace in my basement. Right now, it just has a regular switch to turn it off and on, along with a variable rotary knob to increase the fan speed, which I assume is just a dimmer. What I would like to do at a minimum is add a thermostat so the fireplace will kick off once it hits a set point temp. It would be even better to have the fan turn on and off with it as well. I assume this is a pretty simple job(just getting a standard thermostat)..but I just wanted to make sure. I added a few pictures that may or may not help you.
Thanks for your help guys.
I found this pdf, which appears to be the same model that I have. I did a search for the model number inside, and this came up...all the wiring seems to be spot on.
http://downloads.hearthnhome.com/installManuals/484_980-B.pdf
