Thanks for the help. The conduit is 3/4". Here are some pics of the run.
This one is on the other side of the wall. Comes out under my deck.
Then it's a straight shot to the garage. The panel is under the light. (i'm standing above where the line comes out in this picture)
Got the rods in. Went easier than i thought, for being december in michigan...
They are 8' apart. (the conduit going into the garage is for the sprinkler system)
I had another question about the main breaker. Can i add another ground bar on the right side of this? there seems to be mounts for one. Would that be ok? I'm asking because if you look on the left side, it's a mess. I'd rather connect my new wiring to a new bar, instead of trying to deal with that. Do you think feeding a fourth wire through the conduit, with the other three wires in there would be doable? maybe i'll just leave it 40amps and run the ground wire.
