It is with some coupler brands, or it is with some plug designs. I know that some can be connected by just pushing the plug in, and some must have the ring retracted first. Perhaps it's Milton couplers vs. Generic Junk. At any rate, Milton specified "push to connect" couplers when I bought my "Universal" A-T-M coupler bodies, and again when I dumped the "Universal" for "V".I've never known anyone to connect a Milton style connector without pulling the ring back. Actually, didnt even know it was possible.......???
How would one achieve a pressure drop with a "static test"?"If I am reading that Parker HF graph correctly, the pressure drop is around 17 PSI @ 30 CFM@90 PSI inlet pressure."
That is correct, it is rated in its dynamic state of flow.
If your picture showing your test rig is accurate you are looking at the static pressure drop.
Red
Of course my test is dynamic. The air is flowing out a fixed orifice.
Even with my Quincy compressor running, the 60 gallon tank loses pressure fast during the test.
This temporary setup does exactly what I designed it to do. No more and no less.You're gonna need some better instrumentation before determining your pressure drop.
I'll sit back and watch
Red
If your lucky those gauges are 2.5% no more probably less, of full scale accurate
Good luck
Red
@6PTSOCKET you want to use Milton V -- Good air flow until you get insane amount of air/needs from the one device connected.
Funny video, and really just inventing problems that don't exist in the real world.
Maybe you don't have a connection that high where it requires you to reach UP and OVER something to connect... I can't recall EVER using a connection point so terribly mounted on the wall/anything, or not on a cord real that you can push together more at waist level near your body with ease.
I haven't been doing this forever, but int he last 18 years I've never run into anyone in the shop who's EVER complained about how hard they are to connect... now for sure people have mentioned the code whipping you, etc, but there's solutions for that too that keep the air in or have a 1' whip type that keeps the air controlled.
Not knocking your idea or fix but I just don't see it being a 'real world' problem with anyone I know who works in shops or owns shops.
Just my 02
If you accept the Parker numbers of 17 PSI pressure drop across their 1/4 coupler @90PSI inlet @30CFM then that is interesting.He's measuring his pressure drop at less than your stated accuracy.
He has stated his design has roughly 2/17th of the pressure drop of a well known manufacturer.
Something does not add up
The quality of his "instrumentation " matters when he is making claims.
Red
If for example you are using a 3/4 impact at 90psi at the tool the flow rate would be about 30 CFM since the tool is rated about 7.5 @25 percent duty cvcle.
17 PSI drop per fitting with one on either end of a hose would be 34 plus the pressure drop across the hose could easily total over 40 PSI pressure drop.
However, since the Parker is rated at 90 PSI inlet pressure it would be worse then this.
BTW a 3/4" impact should not be run on a 1/4" bodied quick connect.
I purchased my first impact a CP744 in 1990, 1/2" and attempted to remove lug nuts on my car. They would not come off, switched to a 3/8" hose and coupler and I am pretty sure I could break them by over tightening with that set up.
Red
You should've just turned up the pressure. Same reason why 480v is half the current of 240v both having the same kva. Air tools are rated at 90 PSI for the numbers game but Ive never read anywhere on my Snap-On air tools 90 psi was the maximum pressure. Its a huge chunk of cast aluminum with steel vane motor, I run all mine at 125#
I won't get into Euro or Asian couplers. I'm discussing North American styles only.
There are five main styles. These four, plus ARO. I thought I had re-posed these photos to include ARO, but apparently not. These are all 1/4" bodies. There are other styles for 3/8 and larger bodies.
Milton "V" is a high-flow coupler, it may be the same as a Euro high-flow, but I haven't confirmed that. Note the larger internal diameter.
The Milton "M" is the same as "Industrial Interchange", probably the most-popular style in the USA. Compression testers, leakdown testers and other factory-made tools use the Industrial Interchange system. It's also a US Military standard. You go into some poorly-stocked hardware store, they're going to sell only the "M" style, probably as a crappy Chinese import.
The Milton "T" is a Tru-Flate style, also called "Automotive Interchange". Shortest pilot in the industry.
The Milton "L" is the Lincoln style. Longest pilot in the industry.
Not shown: Milton "A", the ARO style.
The quick-disconnect bodies can be had as "universal", by which I mean they'll accept three of the five styles. I had a "universal" body for a while, but it leaked perpetually with my "T" coupler plugs--the ones with the short pilot. I think they sealed just fine with "M" plugs, and they also fit "A", but I didn't have any of those. So the "Universal" coupler bodies fit "A-T-M" style plugs.
A coupler body that fits Milton "V" will also fit "M" (and "A"???) plugs, but with reduced flow. However, a coupler body for "M" will not fit "V".
I recently converted to Milton V couplers in my shop. IF (big IF) I was willing to stay with Industrial Interchange, my shop would be set up with TST/Oetiker B1 swing couplers. Zero insertion force (except for seal friction) and self-venting when disconnecting. They're somewhat scarce although Amazon has some styles. The B1 is compatible with Industrial Interchange. TST/Oetiker makes other styles also, so be careful.
https://www.amazon.com/dp/B000L9V74S/?tag=atomicindus08-20
Frank, it's hard not to like good 'ol murican cando and ingenuity. Thanks for your sharing your efforts and progress.
It is easy to discount drama, however, whether feigned or sincere. Human kind is a cruel bunch, deeply steeped in skepticism. I suggest that you make a new video, and invite innocent, unsuspecting participants to disconnect each air line, and film them doing it for the first time, with no other instruction from you other than to disconnect the line.
Film the authentic reactions of the participants, which will sufficiently speak for themselves, without absolutely ******* the BS meter like any "look at what I made and how much better it is than anyone else's" self assessment otherwise might do.
The issue isn't that you were being overly dramatic... the issue is that your video comes across that way, no matter how you actually felt. And that first impression is going to be a difficult hurdle for some of your prospective customers to overcome.
Pulling the collar does NOTHING except release the lock preventing the coupler from "swinging". Once the collar is pulled, the coupler can "swing", the movement first blocks the air from the compressed-air tank through the coupler, then a little more movement vents the air from the coupler to the tool. When the coupler has swung far enough, it no longer holds the coupler plug, which can then be readily removed with no pressure behind it. Assembly is the reverse--you push the coupler plug past the rubber seal (seal friction is the only force required to insert the plug) then the coupler body swings which first locks the coupler plug in place, closes the vent, then opens the passageway between the compressed air and the plug (and onward to the tool)I am curious as to how the swing coupling works on disconnection when connected to the pressure side of a hose. When you pull the collar back does it vent and if so do you have to hold it in the vent position until the pressure drops before swinging it to release position?
The "swing" is very similar but not identical to a modern quarter-turn faucet handle--the rotating part is sealed with O-rings around the water passage, when you align the holes, water (air) flows, and when the holes aren't aligned, water (air) cannot flow. There's no vent, of course, in the water faucet.
Not a bit more "dangerous"--and almost certainly less "dangerous" (I'd have said "annoying") than disconnecting a "normal" coupler that doesn't vent before disconnecting.Thanks for the detailed explanation.
Therefore, iif a person is in a hurry and swings it all the way open quickly then that could be dangerous if the plug is connected to a long hose under pressure. Correct?
lol a little over dramatic to the milton v style. thats all we use in our farm shop gotta eat some more wheaties and spinach and grow a pair lmaoOne of the things I don't like about high flow compressed air couplings is the force required to engage them. The explosive decompression during disengagement is also a big problem which is at least solved by so called "safety couplers"
I played around with a few designs of my own and here is a video I made doing a quick and dirty comparison.
FWIW
IT's only a prototype.
Frank
My normal mode of operation has been when disconnecting a blow-gun from a typical Milton quick disconnect, to face the blow-gun upwards, pop the coupler ring with one hand so the blow-gun jets upward, and then grab it with the other hand as it falls. Doesn't seem "dangerous" to me. When disconnecting two air hoses, with considerable stored air, yeah, it's noisy.
I still would like to know what happens when you rapidly swing it past the vent position to the fully open position under pressure. I assume that the plug is ejected under pressure.I used the Oetiker to test leakage of hose assemblies with Nitrogen at 250 psi for years, thousands of assemblies.
The only issue we had was when a coworker had it cranked up to 1000 psi, the end did not pop off violently it was just a scary situation as he new there was a issue and called me over. The 300 psi air hose was rigid as pipe. I lowered the regulator to 250 but it was not a relieving type so I had to vent it at 1000 psi.Now the hose was only 36" long but 3/4" in diameter. With a standard QC it would have been a projectile but with the Oetiker it was not.
Red
