SK vs Snap On Screwdrivers
lightning02
when everything else fails my snap on screwdrivers always do the job without an issue, just wish i could afford a complete set.
DSLTRK
PHELAN, CA
OP, it's essentially Western Forge, vs Snap-On.
Based on my use, they both wear about the same, but the Snap-On Phillips don't seem to cam out as easy.
rice rocket
Screwdrivers ideally should have a narrow diameter, round handle section in the front of the handle. Not a fan of sk pro or cman pro for not having that feature.
Look at beta, facom, pb, wiha, witte etc they all share similar ergonomic bit upfront. even the old school hardhandles have it in many cases. seems like a step backwards to lose that.
This, 100%.
I purchased the SK 6-piece set on SK Day, and sold 'em within a month. The ergonomics are a nightmare. My hands still cramp thinking about it.
Really like my Betas, ergos are similar to my hard handle Stanleys, which, for the price, are still amazing. Basically, tri-lobal anything is better than square. Close your hand into a fist, and try to make a square. Good luck.
rice rocket
I wear mediums, but it's not like it matters, the SK drivers have a different handle size for different head sizes, which I will never understand. Does my hand get bigger when I turn bigger screws? :eyecrazy:
Tri-lobals have tapered handles, so you can slide your hand up or down the handle to find a position that fits your hand the best.
mikebaker1129
Huffman,TX
They dont offer replacements.
I am aware f that.iwas asking if the blades are removable. I will give it a try.
I have older green French made SK/Facom hard handle with a chewed up #1 Phillips tip. I also have a bunch of the Craftsman Pros purchased last year from Sears and HJE. I prefer the hard handles and the smaller handles of the Facom,i was wondering if I could pull the Facom blade and install a replacement?
I figured someone here may have tried it already.
gdocktor3
Connecticut
I have older green French made SK/Facom hard handle with a chewed up #1 Phillips tip. I also have a bunch of the Craftsman Pros purchased last year from Sears and HJE. I prefer the hard handles and the smaller handles of the Facom,iwas wondering if I could pull the Facom blade and install a replacement?
I've never done it, but I believe you can boil some water and let the handle expand a little, then slide the blade out. I'd email SK first and ask if they could exchange it for an exact replacement. They may still have some. Or you can buy brand new ones on eBay. A quick search found these, so I'm sure a #1 Phillips is out there as well. When I see similar items, I message the seller to see if they have other styles available. Worth a shot. https://www.ebay.com/itm/151658075950 https://www.ebay.com/itm/251940265732
btdobie
Southern Minnesota
Cgw1984
Oklahoma city
If op is breaking that many screwdrivers, id question how and why. This sounds much more like misuse than poor quality. In that case id just get whichever cheapest truck screwdrivers i could, be nice to the driver, and hope he keeps warrantying my stupidity.
seber
Deep East Tx.
All sorts of things, always twisting of some sort, if I break them prying I don't claim them. Mainly the smaller ones. One more extreme example: I had a 1/4" screw I cut a slot in and used the my impact on the nut. (yes this is extreme I realize). Snap on broke almost instantly, SK took it no problem. I do have Wera (which I love) but the tips wear sort of fast IMO
That's because they are tempered harder to wear longer. Impact use is abuse and for that you should be using softer steel such as demolition drivers. The fact that the SK stood up to it is a negative in my opinion.
