You may only need to add a ground jumper to the enclosure unless a ground lug is used and the picture angle just doesn't show it. The breakers are fine and so is the enclosure/load center. Make sure those ground wire are routed away from the cb terminals.
The other 100amp panel being in the dettached garage is another story, but considering what you tore out/replaced, this many times better.
