Epoxy and Tile (Brands+Prices)
ckk
Did not see any answers for these 4 questions. Can anyone help out here?
Hey guys,
I'm curious as well about how it holds up with cold weather and snow/water sitting on it.....
I've been flip-flopping for a few weeks now on what to install in my garage. VCT.... no epoxy...... no VCT...... wait a sec, epoxy......... now I'm back to VCT due to the ease of installation (way less prepping).
I just want to make sure VCT has stood the test of time in a similar climate. (I live in Edmonton, Alberta. Winter gets to -40C and the summers get up to +35C)
Thanks guys!
Jason B
PA
No problem with VCT, and there have been plenty of people in Canada with it. Just wax it after you install and you can pour gallons of water ontop :)
yooper
Crestview,FL
HI
I have a enclosed motorcycle trailer. I would like to know if there is a epoxy that will stick to my wood floor in my trailer.
quist11
Started project using rubber tiles from rubber flooring inc to cover old garage floor. Tiles are flexiable so some minor cracks and slight ridge along sides of garage floor is no problem. Appears to be a good product, I'll post pic's when done.
pauloman
cannot really compare a water based epoxy to a solvent free or high solids epoxy.
Also many ways to do an epoxy chip floor (best is a 3 coat system) - cheapo way is to sprinkle chips on the wet epoxy. Also, what amount of chip coverage? 100% coverage requires 1 pound of chips per 7-10 sf.. most epoxies diy kits give you 1 pound of chips...
best to explore your options see www.epoxyproducts.com/floorlinks.html
doubloon
Houston-ish
Would you please add Armorgarage Epoxy kits, they have several. Thanks
Sounds useful, I joined today mainly to research flooring options.
This site is a great resource so far but this thread appears to have lived past its useful life.
The original list in the first post looks like it was created back around 2006 and most of the links are busted, I'm thinking product specifications and prices have changed a little in the past 7 or so years.
It's a good starting list just not terribly convenient anymore.
mrejda
NoVA
First post on the forums, hopefully closing on our first house in late feb, which gives me 2 weeks to get a flooring solution in place for my new to me garage. Slab looks decent, but some light grinding and oil/spill cleanup are a must. 22x23 (506 sq ft), only a small staircase to work around so it will hopefully be straight forward.
Currently trolling CL for some cheap VCT, otherwise leaning towards rust bullet with a clear coat as my other option. Primary use will be parking the family volvo and constant putzing around with an old miata so nothing too heavy duty going on, but hot sticky tires and jack stands will definitely be in the mix.
LegacyIndustrial
deerfield, IL
Grind that slab in preparation and you will have no issues with hot sticky tires.
Hot Tire Pickup: Latin for I did not prep well enough or at all.
elmerbug
Epoxy coatings on concrete floors is one area where using anything less than a quality professional product is likely to lead to regret. Here is my latest garage:
m4UgZPacKn6qqwBG9
Product sourced from garagecoatings.com
Armorpoxy
Agree,
Prep properly, purchase a high quality coating system and you should get many many years of life from the floor.
Manganos
Virginia
Hit up Scotty at Legacy Industrial. I'm just south of you near Richmond and I exchanged emails with him and he told me exactly what I needed to order , product and quanities, and it was at my door a couple of days later. Awesome service.
Chris
wmblanken
Thought I would add on to this, I've been doing WAY to much research on garage coatings and trying to figure out which is "best" for me. As part of that, I tried to get to the bottom of the difference between some of the products that are mentioned often on the site. Some interesting findings that I did not see posted elsewhere:
1. Many of the 100% solids epoxy come from the same manufacturer. If you look at the data sheets for Norclad (aka Original Color Chips), Legacy Industrial, ArmorPoxy, ArmorGarage, ArmorCoat, GarageFlooringLLC, Budget Bob's they are pretty much the same and all seem to match up to what comes from National Polymers, a large private labeler. Not that this is bad, I think its great that we have all of these online companies to supply the DIYer. But, it helped me to get over the worry that I would get inferior product from one vendor vs. another and I can focus on things like price, service, etc.
2. Epoxy Coat, Epoxy Tech, Wolverine are different in that they all use a "cycloaliphatic" chemistry vs. the aliphatic of the above. There are many different opinions of which is "better" but seems like for may garage or the average DIYer either will be fine. It's not clear if these are manufactured by the same supplier (does not seem to be so).
3. Polyurea. There are a number of really interesting polyaspartic polyureas out there that seem like great coatings because they have an unlimited pot life and are easier to use. The offerings from ArmorPoxy (spgx) and GarageFlooring LLC seem to be the exact same thing. The Nohr-s from Legacy is different in formulation with more "solids".
Hope this is helpful to clear up what I found to be a pretty confusing process. I really hesitated to post this as the vendors on here seem like great companies that try hard to offer good advice, but I felt like this would be helpful to others like me that are information junkies and want understand what they are buying. If I in any way misrepresented the above a (I am new to this) then feel free to correct it.
Shea
California
I think you hit the nail on the head right there. The vendors that specialize in concrete coatings carry excellent product. It's not always about saving a buck or two either. Find a vendor with good customer service that you feel comfortable working with and ask questions! We don't sell product and I'm still amazed that people will contact us first to try and solve a problem instead of calling the vendor or manufacturer first. Unless you are experienced at installing floor coatings, good customer service can be the determining factor for a successful outcome. Fortunately the vendors who participate here are great with helping the customer and want you have a great floor you are happy with.
RVJOHNTX
Eagle, Idaho
Epoxy-Coat
Epoxy-Coat (Solvent Based): $0.47ft (Includes Flecks and Installation Kit)
Just spoke to Epoxy-Coat. They said that the 500sq ft kit was $329 not 235?
What am I missing? Thanks
Jason B
PA
I love my VCT! Did my whole 3 car garage for $425!
For any of you that want to do VCT tile, this is a great write-up to follow!
http://www.burtmanindustries.com/images/garage/vct_install.pdf - print it out and get started!
Yep..Ive seen pictures of yours before. It looks awesome.
I still havent installed mine.. I think I'll atleast be waiting until spring. That way I can work with the garage open and get the concrete resurfaced. The resurfacer will probably cost more than the VCT tiles did..
@Tom2 - did you ever do it???
Nightshift
London, Ontario
Jason, I'm about to start doing my 2-car garage floor with VCT after seeing your pictures. My garage floor is very smooth already and 30 yrs old so well cured! I have a couple questions to wrap my head around before I start:
1. in your picture here it looks like you made the transition under your garage doors. Is this a 2-part epoxy "ramp" you did? And does your outer-most tile row extend past the outer edge of your garage doors, or stop underneath at the weatherstrip? I'm not sure how far out my outside row should be. I live in southern Ontario, Canada so we get freezing temps for several months during the winter and I don't know if Roberts 2057 adhesive will hold up if tiles extend beyond the garage door.
2. did you fill in your expansion gaps to eliminate the cracks from telegraphing up thru the tile over time? If so, with what?
You did a fantastic job by the way :thumbup: Cheers, Bill
Jason B
PA
1) you can't see anything when the garage doors are closed. That's transition is an aluminum strip from Home depot, and is 1"x96" long, and 1/8" thick, the same thickness as the tile. It makes a nice transition. When the door is down, from the inside it just barely touches that aluminum, from the inside, from the outside you see nothing.
2) Yes, with Quickrete in the squeezable bottle. I also wanted the tile to be centered on the bigger 2 car garage door on the left, and I wanted to have a full tile when the garage door was opened in that area.
I used the Armstrong S-750 glue. See this below, from a while ago.
It is time to leave the car outside and focus on a product for the garage. More specifically, we are going to take
your drab and boring concrete floor and not only improve the looks, but make keeping it clean much easier. I
don’t need to remind you that a tile floor will make you the envy of all the neighbors too…
Recently, I put finishing touches on covering my garage floor with vinyl composition tile, or VCT. This
commercial-grade flooring is very common and very durable. Most likely, your favorite grocery store, drug
store or even indoor mall uses it. VCT is available in nearly every color and is sold as 12-inch-by-12-inch
squares.
I used Armstrong Imperial Texture VCT for my garage floor. Since I wanted a black-and-white checked look, I
used two alternating colors. I chose Armstrong #51910 (black) and #51911 (white) because they are not solid
colors, but speckled with chips of the complimenting color. The 1/8–inch-thick tiles are resistant to most
chemicals and oils. The colors are solid throughout, so you can sand down any stains, and then wax the tile
back to perfection. Home Depot sells VCT for 59 cents a square foot.
Floor preparation is relatively simple. Sweep and vacuum up the dirt, gravel and cobwebs, then ensure the
floor is smooth. I used a chisel to knock off debris (paint and concrete drips), and filled holes with a concrete
mix (ready-made). The floor must be clean and even. You will be amazed that even the smallest bit of gravel
will show through the tile after it has settled.
The tiles are glued directly to the concrete with an adhesive specifically designed for the job. Keeping it all in
the family, I used Armstrong Glue S-750 ($13 per gallon). Each gallon covers about 10 feet by 20 feet, so I used
three gallons on my three-car garage. For a more permanent application, tiles can be applied with epoxy to
the concrete. This will prevent tile “creep” from wheel camber pressure when dropping cars off floor jacks.
The most difficult part (and most critical) is putting down the first tile. All tiles build off that one, so make
sure it is completely straight. Houses in California are not built perfectly square, so don’t expect your garage
to be either. I decided to snap a perpendicular line off the middle of the garage door. I used that as my
“straight line” for reference and to place my first tile. Visually, it worked out perfectly.
The tile goes down very easily. Spread the glue in sections with a very shallow trowel (1/32 of an inch), and
then let it dry to the touch. The color change of the dried glue is quite obvious, so it is easy to tell when it is
ready for tile.
Place your first tile and then build off that one. The tiles are sized exactly the same, with perfectly square
and straight sides. Push them together firmly (no gaps), then go to the next one. You can cut the tile with a
utility knife, or a special tool (like a paper cutter), as you near corners or obstacles. Upon completion, roll the
floor with a 100-pound-tile-roller (Home Depot/$15 day) to press out any air.
For the best protection against stains, I suggest waxing and polishing the tile to a shine (like grocery store
floors). The floor will resist most chemicals and oils, but I still suggest wiping up spills. Unlike concrete,
sweeping the tile floor with a “dust broom” takes mere minutes to complete.
My home has a three-car garage, with about 610 square feet of floor. I did the entire garage for about $450
(that figure includes tile, glue, equipment rental and tools). If you are interested in contracting the job out, I
was quoted $1 a tile (labor) to have someone else install it. However, they would not allow me to supply the
tile at that price (I would have to buy it from them for $1.24 each). Doing the math, it would have cost me
about $1,400 to pay a contractor to have the floor finished in VCT tile.
Instead, I used my minimal contractor skills, an open weekend, and an investment in materials of less than
$500. The result is a beautiful tile floor that garners continuous comments from nearly everyone who walks by.
SJMaye
Nashville, TN
I totally overlooked VCT until your post. My plant had 120,000 sqft of this stuff. It looked great and was easily patched if damaged. My only issue with it was due to the nature of our work we were endless refinishing the floors.
How often is this needed in a residential garage?
427HISS
I wonder if suppliers and everyone here and other website forums would want a ''Group Buy'' for the tiles ? I've done several through out the years, so I have a lot of experience.
