Do you have a thread on this? My house has crappy reception (either standing very still in one corner of an upstairs bedroom or out on the driveway which gets mighty chilly in the winter), so doing something like this would be a big quality of life improvement for us.
MM
My house belonged to my wife's grandparents. Grandmother passed in 2006, Grandfather passed in 1985. I've started to dejunk the 20x24 that I could barely walk in.
Ten contractor bags of trash that included one petrified hollow possum. I see a dumpster in my future this spring.
Grandfather was the parts manager at the GMC truck facility in Dallas so I'm finding interesting GMC stuff.
Try thisThis.
Then I remembered - that was the drive I had the other 53 'Red Dress Girl' pictures on. 16 were partially/fully youknowwhat. I can't find them on Google again - sorry guys![]()
MM, be a bit careful leaving things in too long in the vinegar. It will continue to eat metal, and it can also strip plating...
Ask Drives about his vise...
I worked out and checked the air in my 2SS/RS Camaro tires.
I plugged mine in yesterday
Detailed my new truck. Told the dealer not to worry with new car prep. since I had the day off today. Did this in the garage I just pulled out to get photos.
I do not know anyone in New Castle that owns a nursing home. Which one?Do you know the guy in New Castle that owns the Nursing Home?
They may not be lucky next week.
What products, pads, and DA did you use?Detailed my new truck. Told the dealer not to worry with new car prep. since I had the day off today. Did this in the garage I just pulled out to get photos.
Was able to get my exterior lights up before the rain. Still have to button up the wiring and for my switch to show up before I can cross it off the list
If you find any old GMC signs, I might be interested in purchasing one from you!
I tried to take inventory. Got broken into over the weekend. I lost about 1500 in tools.![]()
Worked on the Improved windscreen washer pump for my Peugeot. The bottom seal leaks, (on the last 2 that I've bought!)the motor fills with water, it rusts solid. Recently...(great word, covers a multitude of days).. I removed the pump, took it to work and xrayed it to get an idea of the internals, so I cut the top off the motor housing, drilled a drain hole in the motor part of the body, (for next time it leaks) then ground a small flat on the side of the shaft of the new motor from the electronics store, made a seal / washer from xray film (I am an xray tech) so water will?? prefer to go out the drain hole rather than go up into the motor. Sitting here sweating now, (30c, 85f at 11pm!) Wasn't much hotter during the day.
