penright
By the way I am running 3/4 EMT.
Here is my obstruction.
I would like to continue along the bottom of the girt and make the corner behind the pole. There is a product that comes close to allowing what I need.
http://www.garvinindustries.com/conduit-fittings-supports/emt-conduit-fittings/pull-elbows/ecs-75
The problem is I don't think I will be able to get to the screws since they are on the inside.
I did do the 2 45 degree last night. The issue was I wanted to put shelves in that corner and **** up against the pole.
Assuming there is nothing that can be done. I can only think of two options.
1. Go overhead, the only down side is losing symmetry of the conduit in the building. (ring around the girt)
2. Hold the back legs of the shelf proud of the wall, then when I cut shelves allow the back to overhang and but back up with the wall.
