Not saying that anyone should do this, but a couple coworkers and I were debating this.
The original argument was that a neutral line was needed as a return path for current. The counter argument was that my 240v compressor only requires the two hot leads. Each of these leads essentially act as 120v and -120v due to the split phasing to create a 240v potential for the motor. When in operation one lead is the "supply" and the other is the "return", if you're trying to think of current flow. No current should go through ground under normal operating conditions.
So that leads to: 1) Is the above correct? and 2) Do 240v AC compressor motors actually use and need the ground wire as a reference voltage potential? In other words, would the motor still work if the ground was removed?
