myredracer
Anyone know of any youtube vids or websites with a good description on how to smooth out MIG welds on sheet metal and how to use the various tools and discs? Can't seem to find any vids that are worth watching.
Am doing my first restoration on a vintage car body that is needing a lot of sheet metal replaces due to rust. Having a bit of difficulty in getting the welds smoothed down without making the metal thin. Have gone right through a few times and welding that back up is a PITA and can end up making it worse due to distortion. Am getting the hang of doing the welding and have learned how important it is to keep distortion to a minimum. Have been planishing welds and checking with a straightedge as I move along
For tools I have a Dremel, couple of die grinders and 4 1/2" angle grinder and an assortment of cutoff, thin grinding discs and flap discs for all 3 tools, 2" and 3" roloc grinding discs in different grits for the die grinders as well as some roloc surface conditioning discs for them. Also have a Dynabrade belt sander which is great for hard to reach spots.
I'm okay with knocking down the welds pretty close to the sheet metal but it's the final sanding/smoothing that I'm finding are hard. Sometimes the sheet metal has a curve to it and sometimes can be convex/concave which makes it harder. Do I maybe need to swap to a finer grit sanding pad as I get closer to the sheet metal surface or use a conditioning disc and coarse, med. or fine? Also, what tool and disc do I need for inside 90 degree corners? Have tried flap wheel but they seem to wear out way too fast.
